AXI Lite Verification Example
Hi there, I tried to run an example project on Vivado 2017.1 Webpack edition. I found that example on this website https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842507/Using+the+AXI4+VIP+as+a+master+to+read+and+write+to+an+AXI4-Lite+slave+interface. I did exactly what it says but it didn't work and I can't find out the reason. Here is my simulation code and block diagram.
import axi_vip_v1_0_1_pkg::*;
import design_1_axi_vip_0_0_pkg::*;
module bram_test();
bit                     aclk = 0;
bit                     aresetn=0, aresetn_0=0;
xil_axi_ulong 	        addr1=32'hC0000000, addr2 = 32'hC0000004;
xil_axi_prot_t          prot = 0;
bit [31:0] 	            data_wr1=32'h01234567,data_wr2=32'h89ABCDEF;
bit [31:0] 	            data_rd1,data_rd2;
xil_axi_resp_t 	        resp;
always #5ns aclk =   ~aclk;
design_1_wrapper DUT
    .sys_clock(aclk),
    .reset_rtl(aresetn),
    .reset_rtl_0(aresetn_0)
// Declare agent
design_1_axi_vip_0_0_mst_t      mst_agent;
// Transaction method
//task wr_tran();
//    axi_transaction  wr_transaction;
//    wr_transaction   = mst_agent.wr_driver.create_transaction("write transaction");
//    WR_TRANSACTION_FAIL: assert(wr_transaction.randomize());
//    mst_agent.wr_driver.send(wr_transaction);
//endtask
//task rd_tran();
//    axi_transaction  rd_transaction;
//    rd_transaction   = mst_agent.rd_driver.create_transaction("read transaction");
//    RD_TRANSACTION_FAIL_1a:assert(rd_transaction.randomize());
//    mst_agent.rd_driver.send(rd_transaction);
//endtask
initial begin
    #50ns
    aresetn = 1;
    aresetn_0 = 1;
    fork
        //Create an agent
        mst_agent = new("master vip agent",DUT.design_1_i.axi_vip_0.inst.IF);
        // set tag for agents for easy debug
        mst_agent.set_agent_tag("Master VIP");
        // set print out verbosity level.
        mst_agent.set_verbosity(400);
        //Start the agent
        mst_agent.start_master();
    join_none
//        wr_tran();
//        #1000ns
//        rd_tran();
//        #1000ns
        #20ns
        mst_agent.AXI4LITE_WRITE_BURST(addr1,prot,data_wr1,resp);
        #20ns
        mst_agent.AXI4LITE_WRITE_BURST(addr2,prot,data_wr2,resp);
        #70ns
        mst_agent.AXI4LITE_READ_BURST(addr1,prot,data_rd1,resp);
        #20ns
        mst_agent.AXI4LITE_READ_BURST(addr2,prot,data_rd2,resp);
        #200ns
        if((data_wr1 == data_rd1)&&(data_wr2 == data_rd2))
            $display("Data match, test succeeded");
        else
            $display("Data do not match, test failed");
        $finish;
end
endmodule
Capture.PNGI just use BRAM and Master AXI4Lite Verification IPs, others come with "run connection automation".
Hi @sya0,
When you say your simulation doesn't work, what is the failure?
Is the base address for your BRAM 0xC000_0000?
Deanna
