Visitor robin2121
AXI 4 BVALID spec
Hello !
I have a very simple question.
Assume we have in the same clock cycle :
AW_VALID = 1
AW_READY = 1
W_VALID = 1
W_READY = 1
Assume also that we have only 1 Data to send (like AXI 4-lite behavior, AWLEN = 0).
Is it AXI 4 compliant to set HIGH the B_VALID signal from the slave in the same clock cycle ?
I searched on forums and in the AXI specifications (UG 761 and the AMBA spec) but the B_VALID spec seems a little ambiguous for me :
From AMBA spec : Write transaction dependencies
"the slave must wait for both WVALID and WREADY to be asserted before asserting BVALID. The slave must also wait for WLAST to be asserted before asserting BVALID, because the write response, BRESP, must be signaled only after the last data transfer of a write transaction"
From AMBA spec : AXI4 write response dependeny
"the slave must wait for AW_VALID, AW_READY, WVALID, and WREADY to be asserted before asserting BVALID. The slave must also wait for WLAST to be asserted before asserting BVALID because the write response, BRESP must be signaled only after the last data transfer of a write transaction"
The words "before" and "after" are ambiguous while signals are set for an entire clock cycle (theoretically of course).
Could you help me ?
PS : in attach a waveform to see the problem. 2nd case is AXI compliant. My question is about the first case.
Robin,
Voyager
Voyager
Re: AXI 4 BVALID spec
The situation is not really that ambiguous. Note also, from the spec:
So a master or a slave doesn't know the state of its inputs until the rising edge of a clock--i.e., when it samples those inputs.
If an output changes based on a new state of the sampled inputs, that change must necessarily occur after that same rising clock edge that sampled those inputs.
That precludes asserting BVALID before the rising clock edge that the slave uses to sample the W_READY, W_VALID and W_LAST signals--since those signals are used to determine when B_VALID can be asserted.
-Joe G.
Voyager
Voyager
-Joe G.
Visitor robin2121
Thanks ! I missed these lines...
Also note the line below the highlighted one
"must be no combinatorial paths between input and output signals."
Since the only way to drive BVALID high in the same clock as AWVALID and WVALID would be to do it combinationally, the definitions of before and after dont really matter in this case.
That also means you cannot have READYs depend on their VALIDs in the same clock or RVALID on the same clock as ARVALID.
