AXI Traffic Generator IP with high core start pulse
Dear Sir,
I am working on AXI Traffic generator IP. In my design, I am trying to generate random data from IP by giving high core start pulse (core_ext_start), but the design is not working. So, can you please provide some example of this IP which starts generating data after receiving high core_ext_start pulse? I am interested to know about the pulse width of core_ext_start.
Thank you and Regards, Puja Kumari
Re: AXI Traffic Generator IP with high core start pulse
Hi @puja ,
Did you check how it is done in simulation in the example design integrated in vivado?
I would assume that a 1 clk pulse would be enough. Make sure this is a real pulse (low -> high -> low)
Hope that helps,
Florent
Hi @florentw
In example design of vivado, external start and stop are not used. Instead, s_axi interface is used.
I simulated design with 10ns clock, reset active for 100ns and start pulse of 10ns. Random data is not being generated. Handshake signal of axi stream interface is not in an active state.
Please help me to debug this issue.
Puja Kumari
Hi @puja ,
Can you share your design?
Florent
Hi @florentw ,
I added AXI Traffic generator IP to my design. Then I wrote following testbench:
module testbench(
parameter CLK_PERIOD = 10;
parameter RESET = 100;
parameter start_width = 10;
reg s_axi_aclk;
reg s_axi_aresetn;
reg core_ext_start;
reg core_ext_stop;
wire m_axis_1_tready;
wire [31:0] m_axis_1_tdata;
axi_traffic_gen_0 DUT(
.s_axi_aclk(s_axi_aclk),
.s_axi_aresetn(s_axi_aresetn),
.core_ext_start(core_ext_start),
.core_ext_stop(core_ext_stop),
.m_axis_1_tready(m_axis_1_tready),
. m_axis_1_tdata( m_axis_1_tdata)
initial
begin
s_axi_aclk = 1'b0;
forever #(CLK_PERIOD/2) s_axi_aclk = ~s_axi_aclk;
end
initial
begin
s_axi_aresetn= 1'b0;
#RESET;
s_axi_aresetn = 1'b1;
end
initial
begin
core_ext_start= 1'b0;
#(RESET+3);
core_ext_start = 1'b1;
// # start_width
// core_ext_start= 1'b0;
end
initial
begin
core_ext_stop= 1'b0;
end
endmodule
Puja Kumari
Hi @puja ,
Could you zip you full project and attached it to the topic?
This would help to see how the Traffic generator is added (also I would need the coe file -> I assume you have added them? If not it could be what your issue)
Florent
Hi @florentw ,
PFA
Puja Kumari
HI @puja ,
One mistake is obvious. You didn't set m_axis_1_tready. If this is not high, the ATG will not send any data.
Also you might need to take care of the interfaces you are not using (S_AXI and S_AXIS). This is never good to leave signals unconnected and undriven.
Florent
Hi @florentw ,
Please find the attached zip file of design.
Now I am using the IP in master loopback mode. I have connected M_AXIS_MASTER interface to S_AXIS_MASTER interface. Still, random data is not being generated. Now, m_axis_1_tready is high, but s_axis_tvalid is always low. I don't the reason behind it. Please help me out to understand this. Please find the attached simulation result.
Also, I do not know how to take care of unconnected interface. Now S_AXI is an unconeected interface in my design.
Puja
HI @puja ,
You need to look into the documentation to konw how to properly connect the AXI interface.
Florent
Hi @florentw ,
I read PG025-AXI Traffic Generator IP Product guide. I could not find what to do with S_AXI interface in case of Master Loopback mode. Also, I am not sure whether unconnected S_AXI interface is the reason for random data not being generated on M_AXIS_MASTER interface.
Please help me to resolve this issue.
Puja Kumari
@puja wrote:
Hi @florentw ,
[Florent] - I already did. You need to connect the AXI interface properly. I am not gonna do all the work for you.
Puja Kumari
Florent
