Visitor arcolima
Custom AXI IP address blocks not exported to SDK
I am designing a custom video IP in VIvado 2018.1.
I packaged my VIDEO_IP, generated from a block design that includes 7 sub-IPs: some are Vivado Catalog cores, some are custom written IPs.
I defined an address block for each sub-IP, and with address editor I mapped the blocks in the external slave S_AXI, as follows:
External Masters
S_AXI (16 address bits : 0x0000 [ 64K ])
G_BRIDGE
S_AXI_LITE
Reg
0x3000
4K
0x3FFF
S_BRIDGE
S_AXI_LITE
Reg
0x4000
4K
0x4FFF
TPG
axi_lite_ctrl
Reg0
0x5000
4K
0x5FFF
LUT_0
s_LUT_axi
Mem0
0x1000
4K
0x1FFF
LUT_1
s_LUT_axi
Mem0
0x2000
4K
0x2FFF
reg_space_0
s00_axi
reg0
0x0000
4K
0x0FFF
v_mix_0
s_axi_CTRL
Reg
0x8000
8K
0x9FFF
When exporting this project to SDK, only the address block at the highest offset (V_MIX in this case) is mapped and can be accessed, all the other block are unreachable,
The reason is that in the base_zynq_design.hwh file exported by Vivado, the VIDEO_IP peripheral's address space is defined by C_BASEADDR and C_HIGHADDR that always match the values of the highest address block
<PARAMETER NAME="Component_Name" VALUE="base_zynq_design_VIDEO_IP_0_0"/>
<PARAMETER NAME="EDK_IPTYPE" VALUE="PERIPHERAL"/>
<PARAMETER NAME="C_BASEADDR" VALUE="0x40028000"/>
<PARAMETER NAME="C_HIGHADDR" VALUE="0x40029FFF"/>
</PARAMETERS>
Why is the peripheral's address space reduced to the highest block only? What am I missing? Any suggestion?
Re: Custom AXI IP address blocks not exported to SDK
Hi @arcolima,
Please check this AR: https://www.xilinx.com/support/answers/66322.html
Best Regards,
Srikanth
