Visitor jigverb
Zynq UltraScale+ ZDMA interrupt error
Custom bsp/RTOS driver for PS FPD ZDMA on APU A53.
I use scatter-gather mode, with linear descriptors, and do not enable the INTR bit in src/dst buffer descriptors (refer to Table 19-3 , UG1085, v1.9)
However, I do enable the DMA_DONE interrupt per the Interrupt enable below (https://www.xilinx.com/html_docs/registers/ug1087/ug1087-zynq-ultrascale-registers.html)
1. What exactly is DMA_DONE interrupt?  If I only rely on DMA_DONE in scatter-gather linear mode, then would ZDMA interrupt me when all descriptors are done?  And would it be equivalent of enabling the INTR bit in the last destination descriptor?
2. Need more info on BYTE_COUNT_OVRFL error on ZDMA module:
Although there is an explanation in the right column, it is quite vague.
What exactly does this error mean, and what can cause it?
thx,
