Observer zxm02370303
vivado bfm mpsoc library simulation 64 bit address
vivado bfm mpsoc library simulation write_data can't access 64 bit address,
when use write_data(64'h400000000,4,32'h12345678,response);
the log said out of range.
i wonder if there is limitation on write_data usage or parameter width.
Thank you very much.
Re: vivado bfm mpsoc library simulation 64 bit address
Hello @zxm02370303
The Zynq Ultrascale+ MPSoC Verification IP Documentation can be found here: https://www.xilinx.com/support/documentation/ip_documentation/zynq_ultra_ps_e_vip/v1_0/ds941-zynq-ultra-ps-e-vip.pdf
On page 7 it talks about the write_data function call which limits addresses to 32-bits.  For any questions about usage regarding the Verification IP API, the above document would probably be the best bet.
Thank you,
Caleb
Caleb
