benedetto73
Alveo U280: which SLR regions can use HBM?
Alveo U280 docs say that only SLR 0 has direct connection to HBM.
Does it mean that with other SLRs it is NOT possible to connect to HBM...
... or that it is possible but just slower?
driesd
Hi Benedetto
The physical wires to the HBM silicon are connected directly to SLR0 (at the bottom).
SLR0 is the bottom SLR.
The other SLRs have indirect connections through SLR0.
Is it slower? That depends on how much latency you can have. With enough pipelining registers, you can reach even the top SLR at full rate.
Best regards
Dries
Give Kudos to a post which you think is helpful and reply oriented by clicking the star next to the post.
driesd
Hi Benedetto
Best regards
Dries
