UNKNwYSHSA
Fail to update alveo shell
Here is the information from dmesg when i run command: "sudo ./xbmgmt flash --update --shell xilinx_u200_xdma_2018..."
[  128.618994] xclmgmt 0000:07:00.0: xmc.m.12582912 ffff969698997810 _xocl_drvinst_open: OPEN 1
[  128.632243] xclmgmt 0000:07:00.0: xmc.m.12582912 ffff969698997810 xmc_erase_sc_firmware: erasing SC firmware...
[  139.108847] xclmgmt 0000:07:00.0: xmc.m.12582912 ffff969698997810 xmc_mailbox_wait: XMC packet error: 7
[  139.108854] xclmgmt 0000:07:00.0: xmc.m.12582912 ffff969698997810 xmc_update_sc_firmware: can't erase SC firmware
[  139.108893] xclmgmt 0000:07:00.0: xmc.m.12582912 ffff969698997810 xocl_drvinst_close: CLOSE 2
[  139.108895] xclmgmt 0000:07:00.0: xmc.m.12582912 ffff969698997810 xocl_drvinst_close: NOTIFY 0000000004535826
How to fix this problem?
Before it, i run "sudo ./xbmgmt flash --scan", and output is:
ERROR: SC is not ready: 0x0
Card [0000:07:00.0]
    Card type:		u200
    Flash type:		SPI
    Flashable partition running on FPGA:
        xilinx_u200_xdma_201830_2,[ID=0x5d1211e8],[SC=UNKNOWN]
    Flashable partitions installed in system:
        xilinx_u200_xdma_201830_2,[ID=0x5d1211e8],[SC=4.2.0]
JohnFedakIV
Hi @UNKNwYSHSA ,
Thank you for the post. It looks like the update failed when trying to flash the SC firmware, I believe this is directly related to the SC issue on your other thread - https://forums.xilinx.com/t5/Alveo-Accelerator-Cards/Validate-U200-failed/td-p/1168444.
Let's work together on that first thread and we can reopen this if this issue still exists after.
~John
* Please don't forget to reply, kudo and accept as a solution! *
