a7med
Problem-with-xilinx-u250-xdma-201820
a7med
Fo any one who encounter the same issue. I managed to solve the issue by installing newer XRT (201830) and then installed the ml-suite shell for u250 (201820) then the flashing command went through. My guess because the U250 had newer 201830 shell DSA, the XRT (201820) couldn't detect it so it reported as Unkown and failed.
After flashing, I uninstalled XRT(201830) and installed the (modified XRT built from source due to new linux kernel name clash bug https://github.com/Xilinx/XRT/issues/1717) for 201820 branch. then the ml-suite examples finally worked
a7med
a7med
correction, I had to use the 201830 as 201802 still not working
