nthomas
U25 board file wrong for Ethernet
Using the Vivado "Board" menu in IpIntegrator Bloock Design to add the "QSFP Connector 0" or "QSFP Connector 1" produces the error "ERROR: [IP_Flow 19-3461] Value 'Quad_X1Y12' is out of the range for parameter 'GT Selection(GT_GROUP_SELECT)' for BD Cell 'xxv_ethernet_0' . Valid values are - Quad_X0Y1, Quad_X0Y2, Quad_X0Y3, Quad_X0Y4"
I am trying to add a 10G/25G Ethernet Subsystem. I am using the latest U25 board file (board schema_version="2.1" vendor="xilinx.com" name="au25")
In the board file "preset.xml" the preset Quads used for qsfp0 and qsfp1 are Quad_X1Y12 and Quad_X1Y11 respectively.
Looking into the Re-customize IP of this block manually, it is not possible to select Quad_X1[N], only QUAD_X0[N].
Is this an issue with the preset.xml file, or are the QSFP connectors truely on Quad_X1Y12 and Quad_X1Y11? If so, how can I connect to them?
JohnFedakIV
Hi @nthomas ,
Thank you for highlighting. This is is an issue with the board files, I checked with the team and they are working on updating them - I don't have a timeline for a fix and will update this topic when I have more information.
~John
* Please don't forget to reply, kudo and accept as a solution! *
JohnFedakIV
Hi @nthomas ,
~John
JohnFedakIV
Hi @nthomas ,
I've received an update on this that the team is hoping to have the U25 board files updated and posted to the lounge by mid-May.
~John
