vconst89
U50, Ethernet Card
Hi, according to this document, the shell xilinx_u50_gen3x16_xdma_201920_3  includes ethernet card features.
https://www.xilinx.com/support/documentation/boards_and_kits/accelerator-cards/4_0/ug1361-alveo-card-validation-test-solution.pdf
How can I make this card available as NIC/Ethernet interface in Ubuntu 18.04?
JohnFedakIV
Hi @vconst89 ,
I've learned of a newly released OpenNIC project that does make an Alveo card (U250 and U280) available as a NIC interface with Ubuntu - it is found here: https://github.com/Xilinx/open-nic
This was released last week and does have a few limitations:
  1. The performance is limited and will not reach 100Gbps
  2. It does not implement most of the ethtool capabilities
  3. There have been issues when trying to use this within a VM
~John
* Please don't forget to reply, kudo and accept as a solution! *
erliang
have you made it?i want to make it available on centos7.8,but dont know how to get it
JohnFedakIV
Hi @vconst89 ,
I want to note that the team has released the next version of xbtest, v5, which can be found here: https://www.xilinx.com/products/acceleration-solutions/xbtest.html (updated UG1361 is here: https://www.xilinx.com/support/documentation/boards_and_kits/accelerator-cards/5_0/ug1361-alveo-card-validation-test-solution.pdf)
This testing doesn't instantiate the card as a NIC/Ethernet interface on the host, but uses XRT with the platform's regular PCIe connection to communicate with an Ethernet/GT kernel. The kernel is similar to this example:
https://developer.xilinx.com/en/articles/designing-a-transceiver-based-application-with-vitus.html
~John
JohnFedakIV
Hi @vconst89 ,
~John
