mdpuma
failure in dumping .xclbin file onto alveo u250
im getting this message in console after generating bin file and try to program using API calls.
Console output redirected to file:/home/User/MOUNIKA/vitis_flow/Hardware/vitis_flow-Default.launch.log]
XRT build version: 2.3.1301
Build hash: 192e706aea53163a04c574f9b3fe9ed76b6ca471
Build date: 2019-10-25 03:04:42
Git branch: 2019.2
PID: 20319
UID: 1000
[Tue Jan 28 10:51:57 2020]
HOST: mdstsrapt
EXE: /home/User/MOUNIKA/vitis_flow/Hardware/vitis_flow
[XRT] WARNING: No devices found
[XRT] ERROR: No devices found
Error: Failed to find an OpenCL platform!
Test failed
mcertosi
Hi @mdpuma
Can you show me the output of the below command?
$sudo lspci -vd
Did you follow the steps in UG1301 to flash the card with a platform and install the development shell on your computer?
M
mahinlman
Validate XRT,
<XRT_dir>/bin/xbutil validate
if, failed to validate.
Then reinstall XRT & xdma.
run flash, cold reboot your machine.
mcertosi
Hi @mdpuma
$sudo lspci -vd
M
mdpuma
Thank you I tried updating the shell again. Now my card got detected.
