xilinx675942236
installing XVC drivers
hi
When installing XVC drivers according to the manual of PG156, make install error, as follows:
make -C /lib/modules/4.15.0-47-generic/build M=/home/alveo-u200/soft/u200/xvc_pcie/driver_v0.4 modules
make[1]: Entering directory '/usr/src/linux-headers-4.15.0-47-generic'
Makefile:976: "Cannot use CONFIG_STACK_VALIDATION=y, please install libelf-dev, libelf-devel or elfutils-libelf-devel"
CC [M] /home/alveo-u200/soft/u200/xvc_pcie/driver_v0.4/mmconfig-shared.o
/home/alveo-u200/soft/u200/xvc_pcie/driver_v0.4/mmconfig-shared.c: In function ‘pci_mmcfg_driver_init’:
/home/alveo-u200/soft/u200/xvc_pcie/driver_v0.4/mmconfig-shared.c:118:2: error: implicit declaration of function ‘acpi_get_table_with_size’ [-Werror=implicit-function-declaration]
acpi_get_table_with_size(ACPI_SIG_MCFG, 0, &mcfg_base, &mcfg_size);
cc1: some warnings being treated as errors
scripts/Makefile.build:332: recipe for target '/home/alveo-u200/soft/u200/xvc_pcie/driver_v0.4/mmconfig-shared.o' failed
make[2]: *** [/home/alveo-u200/soft/u200/xvc_pcie/driver_v0.4/mmconfig-shared.o] Error 1
Makefile:1552: recipe for target '_module_/home/alveo-u200/soft/u200/xvc_pcie/driver_v0.4' failed
make[1]: *** [_module_/home/alveo-u200/soft/u200/xvc_pcie/driver_v0.4] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-4.15.0-47-generic'
Makefile:21: recipe for target 'module' failed
make: *** [module] Error 2
I am completely installed in the manual, why is this?
bethe
Hi @xilinx675942236  & @luisb,
You are missing a dependancy in your Ubuntu installations, please try:
sudo apt-get install libelf1    -or-
sudo apt-get install elfutils
After applying this to my Ubuntu build, I was able to successfully make clean all, sudo make install, and sudo modprobe the driver, and see it attach.
luisb
I'm getting the same error.  What OS and version are you using?  I'm using Ubuntu 18.04 and I'm wondering if you're using the same.
xilinx675942236
I am using ubuntu 16.4 ,Installation has been wrong。Is it not supported by the ubuntu?
bethe
