u250 not listed in lspci on lenovo thinkstation p520
I plugged the active cooled u250 into a 16x pcie slot next to a gpu. When I power up, the 3 colored leds blink a little and then the blue programmed led comes on. I can also connect to the card with usb/jtag and program it with a bit file I made myself after the fact.
The problem is lspci doesn't see the card even without the jtag cable disconnected. It comes up & get programmed but no lspci output.
Any suggestions?
Re: u250 not listed in lspci on lenovo thinkstation p520
I managed to make a U250 work in a P520.
Have you checked the BIOS settings for the PCIe slot where you put the U250? (e.g. is the slot enabled?)
Hi @muzaffer -
Was the card visible in lspci with the Golden image (i.e. prior to loading any custom bit file)?   If you can revert to Golden (via instructions at https://www.xilinx.com/support/answers/71757.html) and check that will help determine the problem set.
