Newbie aeltawil
MAP using MFP
I created a project using ISE9.2. Afetr synthesis, mapping and place and route, I got some timing violations. To fix those, using floorplanner I manually made some minor changes and by saving it, *.MFP and *.FNF were generated. Now to map the design using the new constraints (that I manually impose through floorplanner) ISE/map tool version J 40 doesn't allow -fp option. How can I use the new constraint file (*.MFP) in the map/par process?
Re: MAP using MFP
Just make sure your constraints are written to the ucf file.
After that, an MFP file is not necessary after that.
