Actual Read/Write Width FIFO Generator v9.3 question
Need to generate a FIFO that will write 64, 64-bit data values, and be able to read that data 16-bits at a time.  Independent clocks.
The v9.3 GUI states that the Actual write depth is 63 and the Actual read depth is 252.  Does this imply that I can't read all of the data that I wrote?
Do i have to bump up the write depth to 128, and use programmable thresholds to get the actual write and read depths equal to 64, and 256, respectively?
Re: Actual Read/Write Width FIFO Generator v9.3 question
you can increase the depth to 128 and can set the programmable full threshold to 64 and programmable empty threshold to 256 to control the data input and output  from the FIFO as per your requirement.
Satish
yes the actual depth will be different from the configured depth depending on the parameters selected.
However you can read all the data that is written into the FIFO.
Input actual data written 64*63=4032 and actual data read will be 16*252=4032.
If  you require exactly 64*64=4096 for your application then you can go for higher depths.
Satish
Yes, I would require exactly 64x64 so I would have to increase the depth. Only thing is I need an indication that all 64 x 64 have been read and written. In that case, I sort of need a pseudo half full/empty flag.
Satish
please refer below ARs
http://www.xilinx.com/support/answers/23075.htm
Thanks and Regards
Balkrishan
