Observer kane06
Moving data between rams with different width
I'm building a project that need to move data from DDR to BRAM with DMA, and when I find that I can configure the data width of BRAM, I have the following questions:
What happens when we move data between rams with different width?
For example, when moving data from 32-bit wide DDR to a block RAM of 64-bit wide, do we lost the higher 32 bits?
And when we move data from a 64-bit BRAM to a 32-bit DDR, how can we fit it in?
Re: Moving data between rams with different width
I don't know your DMA design but if I reading twice and writing once it would appear as the latter;
0 aaaa_bbbb
1 cccc_0000
Mike
Scholar dpaul24
@kane06,
Data should not be lost. There are two ways:
1. You generate the BRAM with 32 bits width.
2. You introduce a FIFO b/w the DDR and BRAM. One side of the FIFO will have 32 bits width and the other will have 64 bits width.
FPGA enthusiast!
All PMs will be ignored
do a 64b read followed by two 32b writes
OR
do two 32b reads followed by a 64b write
Observer kane06
Actually, I have to use a larger width. What I want to know is how the data is stored in this case.
For example, when I use DMA to move data from ddr(16 bit for simplicity purpose) to ram(32 bit), what would happen?
In the ddr, data is like:
addr   data
0        aaaa
1         bbbb
2         cccc
now I ask DMA to move these data to BRAM, would it be like this:
addr   data
0        0000_aaaaa
1         0000_bbbb
2        0000_cccc
or like this?:
addr   data
0         aaaa_bbbb
1          cccc_0000
0 aaaa_bbbb
1 cccc_0000
Mike
