Does ISE 14.x version work on windows7 or higher?
I am wondering if ISE 14.x will run on Windows 7?  I've read that ISE14.x only
work under Window XP.  I've just recently bought the CoolRunner Starter board
from Digilent and I only have Windows 7 OS.  And supposedly the ISE GUI
that download the program onto CoolRunner only works with XP OS.
Re: Does ISE 14.x version work on windows7 or higher?
Well I was able to obtain this info that ISE 14.7 supports:
 . Windows 7 Professional (32-bit and 64-bit), English/Japanese
If I only the regular Windows 7 version (non-professional), would it work?
Hi @andy92806
I expect it to work as there are not much difference between different versions of Windows 7.
Vinay
andy92806 -- I am wondering if ISE 14.x will run on Windows 7?
ISE 14.x will run on /Windows 7 Pro 32/64-bit/WindowsServer 2008. No issues.
FYI: The supported operating systems (O/S) in different versions of ISE tools mentioned in http://www.xilinx.com/support/answers/18419.html
andy92806 -- And supposedly the ISE GUI that download the program onto CoolRunner only works with XP OS.
CoolRunner CPLD’s should work with all supported O/S in ISE14.X.
FYI: The supported devices in different versions of ISE tools mentioned in the following Answer record http://www.xilinx.com/support/answers/15938.html (Please refer http://www.xilinx.com/publications/matrix/Software_matrix.pdf for ISE13.X & ISE14.X tools)
I use ISE 14.7 on my Win 7 Pro 64-bit computer.  The GUI and other parts of ISE run just fine.  I assume that ISE would run on other versions of Win 7, too.
