Newbie satish.drm
XC9536 15C Uart PROGRAMMING
Hi all,
greetings of the day...
I am new to this CPLDs and I have XC9536 15C with me. I do some sort of experiments on my own developed kit and I do some LED blinking,7-segment display control and some TIMER programs(in VHDL using ISE) on it. Now i want to do SERIAL communication i.e, UART program on this XC9536, But I even don't know how to do it or whether it support or not??
Please help me out with some suggestions to develop UART communication using XC9536.
Thanks in advance.
Re: XC9536 15C Uart PROGRAMMING
Newbie balu_408
hi .. can i have some more detailed architecture regarding XC9536 15C
also can u specify the replacement Ic for XC9536 15C
Scholar pratham
@balu_408 This PRODUCT is OBSOLETE. If you check the PDN there is no direct replacement available
-Pratham
Newbie balu_408
since i am new for xilinx programming ... i had to redesing the existing board where this IC has been using since 4 years ,
i need to replace it any have and re design the board, i have knowledge in other processors and controllers, like ARM, PIC and 8051 controllers ,
i need to know the complete application details about XC9536 15C , so that i may choose any of these controller .
or u can suggest me for any one of the xilinx IC to replace this one.
i realy thank you for ur quick response.
The XC9500 family datasheet is here:
http://www.xilinx.com/support/documentation/data_sheets/DS063.pdf
The XC9536 datasheet is here:
http://www.xilinx.com/support/documentation/data_sheets/ds064.pdf
A common replacement devices for the 9536 is the 9536XL.  The architecture is similar, but bigger and the pin out is compatible. A design that fits in a 9536 will fit in a 9536XL. However it is a 3.3V core, as opposed to 5V for the 9536.
Arthur
