Barcode database - how to search by JTAG DNA?
Xilinx 2d barcode application allows device lookup via JTAG DNA, but no working example is provided for this type of search.
1st question is how to retrieve device DNA data by barcode serial number. Usually database record found by barcode SN includes DNA field, encoded as some alphanumeric value with several underscore-separated sections. How to translate this information to raw DNA 96-bit (57 bit for 7 series) value?
Second Q is about DNA format required by the search tool. I've tried both raw DNA hex string as read out by Vivado programming tools and that alphanumeric value w returned by database search. Both tries yield no results.
BTW, are there any API to automate barcode database access to get DNAs from barcode SN and vice-versa?
Re: Barcode database - how to search by JTAG DNA?
Hi @memset
Did you checked https://www.xilinx.com/support/answers/67513.html ? I believe it provides all necessary information related to 2D Barcode.
Bhushan
@bpatil wrote:
Hi @memset
Hello!
JTAG DNA how-to is not covered by currently available materials, including AR #67513.
The only sentence related to my question is "Please contact your local sales representative for more information or 2dbarcodehelp@xilinx.com for further details."
And I've tried forums first.
Participant baxter2002
Same here. How to retrieve a PL DNA from a 2D Code like: XD6MD6YIU180xxxx ?
