Visitor dingqy
Cannot connect to the basys 3
I successfully install the vivado and also install the cable drivers but they weren't shown in the windows device management. If I try to add the drivers by myself, it shows that the device does not wort (error code 10). My operating system is win10 64bit. I try to use the wdreg but my systems didn't have such a command and a executable program. Thank you very much.
Re: Cannot connect to the basys 3
Hi @dingqy
Are you able to detect JTAG cable in Device Manager ? like below:
If you are using Platform USB Cable, is it getting detected in Device Manager? please share the snapshot
Since you tried installing the drivers by yourself and got a error.
Please install the JTAG Digilent USB Drivers/Platform(Xilinx) USB  manually, without uninstalling Vivado by following this AR#59128.
After installing Drivers, please reboot your system to re-initialize USB buses.
Hope this helps.
Deepak D N
Please reply or give kudo or Mark it as an Accepted Solution.
Hi @dingqy
Hope this helps.
Deepak D N
Visitor dingqy
Hi, ddn. Thank you very much and I have solved the problem because I use the microusb cable that didn't work well.
