Kintex-7 SPI Master Configuration Fail.
Hi all,
I designed a board using Kintex-7 FPGA. Only one of several boards has a configuration fail at boot-up. The power-on sequence is VCCINT, VCCBRAM, VCCAUX, VCCAUX_IO, and VCCO. The board with the issue has the following symptoms.
The SPI master signals (cs, clk) are output before the Program_B ramp starts. (VCCO ramp is the same as Program_B.)
I have some questions.
1. When can this issue occur?
2. What is the threshold voltage of the program_b signal?
3. What is the threshold voltage of VCCINT, VCCBRAM, VCCAUX, VCCAUX_IO, and VCCO (2.5V, 3.3V and 1.8V) in power-on sequence to start the power-on reset?
Re: Kintex-7 SPI Master Configuration Fail.
[ Edited ]
looks like you have a 50 ms rise time on that prog_b,
Whats your vcc ramp time, does it meet the specs ?
what size pull up do you have , prog_b needs less than 4k7, I'd usually use 1K
Hi drjohnsmith,
Thank you for your response.
All VCC ramps are less than 50ms. It seems to satisfy the spec. And the pull-up resistor for prog_b is 4.7 Kohm.
Thank you.
so what is your power on reset circuit ?
you need to hold off doing anything till after the power is within spec,
     Your flash clock seems to start way before the power is stable / within specification,
can you post the power on reset circuit your using please,
