Visitor tneto
Master BPI Configuration Interface
Hello. Both, Xilinx and Micron pointed out MT28EW01GA as the recommended part to be used together, but so far there is no guideline available. Even on latest kits, Xilinx stills promoting an obsolete part. So is there any suggestion or schematic that proofs that this combination really works and/or some statement that addresses the new memory pins "BYTE#" and "RY/BY#"? Thanks.
Re: Master BPI Configuration Interface
Hello @tneto,
Yes, its true that some of the Micron flashes are going EOL and there has been call of last purchase from Micron for this flashes.
Are you looking for synchronous BPI flashes ?
For which device you are looking for parallel BPI nor flashes ?
Is there any requirement of fast configuration speeds ?
Please answer above questions.
Thank you.
Visitor tneto
Hello @kvasantr. Thanks for looking into my post. The memory I've selected so far is MT28EW01GABA1LPC-0SIT. Asynchronous is acceptable and no special requirement on configuration speed. My concerns are on new pins BYTE# and RY/BY#. Currently pull them up seems okay to me but I'd have your confirmation if they need to be mapped on FPGA or not. If yes please point me the special pins where to connect. Thank you.
hi @tneto,
can you please let us know which version of the tool your using and FPGA part number.
Ta
sekhar
Chandra sekhar
Kindly note- Please mark the Answer as "Accept as solution" if solution provided is helpful.
Visitor tneto
Hello @csattar. For Vivado I'm currently on 2017.2 but always able to get the most updated one and FPGA part number, XC7VX690T-3FFG1761C. Thank you.
Visitor andrew3huang
Hi, Due to EOL of MT28GU01GAAA1EGC-0SIT, we modified our XC7V2000T board to use MT28EW01GABA1LPC-0SIT. Since MT28GU01GAAA1EGC-0SIT is a 16 bit NOR and we also pull up the BYTE# pin of MT28EW01GABA1LPC-0SIT. We connected the same address of MT28EW01GABA1LPC-0SIT as MT28GU01GAAA1EGC-0SIT from XC7V2000T. Connect MT28EW01GABA1LPC-0SIT pin E2(A0) to XC7V2000T pin AH31(IO_L24N_T3_A00_D16_14). After the new FPGA board come back, Vivado is able to erase and program the MT28EW01GABA1LPC-0SIT chip. But it fail on "Boot from Configuration Memory Device". Do we need to connect MT28EW01GABA1LPC-0SIT pin E2(A0) to XC7V2000T pin AG31(O_L24P_T3_A01_D17_14) ? Thanks!! Andrew
