Visitor fzhu129
customized bit stream programmed into qspi of VCU118 cannot be loaded into FPGA
Hi All:
I am using VCU118 evaluation board.
I can program original .mcs file from board into FPGA of VCU118 but
When I program our customization .mcs file successfully, but it is found that loading of flash
failed and configuration cannot be done. It works before.
Any ideas upon how to fix this problem?
Thanks and best regards
Frank
Re: customized bit stream programmed into qspi of VCU118 cannot be loaded into FPGA
Hi @fzhu129
Are able to program FPGA with bit file of your design through JTAG?
What customization you are performing in original (Working) .mcs file.
Provide status register details after mcs loading fail.
Bhushan
