Participant 2010stone
Creating my own FFT example
Hello, I want to learn how to use the FFT block, my plans to learn it is to make my own easy example. I pretend to put in the FFT a  variable vector with 64 elements from the workspace and return the output of the FFT to workspace as other variable.
My questions it´s how can I put a variable of the workspace into simulink framework?
What block is supposed I have to conect to in blocks?
What block is supposed I have to conect to outputs blocks?
Thank you for your valuable help.
Re: Creating my own FFT example
Go to "Simulink Library Browser",
For the input, use Simulink->Sources->From Workspace
For the output, use Simulink->SInks->To Workspace
Cheers,
Jim
Hi have also a look at the fft example in the Xilinx blockset demos
Mike
