Observer alex9
Time constraint
An integration will be done on every 1024 points, then a divider need to be done on the integration results. By using the Cordic divider, it take quite long time to refresh the result. As the attached screen, I cannot compare or confirm the result is correct, Also, I need to control that every 1024 points, there will be a divider result come out. MMay you give any suggestion, thanks.
Re: Time constraint
You can use the "To Workspace" to dump the results and compare them.
You can also add a delay to the output of the Simulink bock to try and match the latency of the CORDIC divider.
Chris
Video Design Hub | Embedded SW Support
