Observer zorz123
Darknet 2 Caffe Quantize problem incorrect shape
How to convert YOLOv3-tiny darknet to caffemodel
Hi All
I tried darknet2caffemodel conversion tutorial (https://github.com/Xilinx/Edge-AI-Platform-Tutorials/tree/master/docs/Darknet-Caffe-Conversion).
I have converted default/example YOLOv3 darknet model to caffemodel, and it is successfully running on ZCU102 board.
Next step, I try to convert YOLOv3-darknet model which is downloaded from https://pjreddie.com/darknet/yolo/. modify as below:
1. Classe 80 -> 1
2. filters: 255 -> 18
I do teach base on 1 classe and 18 filters .
3 darknet training create weight file about 256 Mb (it is correct, i verify result is ok )
4. Try convert darknet 2 caffe base on xilinx tutorial as follow:
bash -v 0_convert.sh
# step 1: test Darknet and Caffe YOLOv3 models
bash -v 0_test_darknet.sh
bash -v 1_test_caffe.sh
# step 2: quantize YOLOv3 Caffe model
cp 1_model_caffe/v3.caffemodel  ./2_model_for_quantize/
bash -v 2_quantize.sh
0604 11:20:22.077857  1844 net.cpp:310] This network produces output layer93-conv
I0604 11:20:22.077980  1844 net.cpp:330] Network initialization done.
I0604 11:20:22.078330  1844 net.cpp:869] Ignoring source layer input
F0604 11:20:22.105778  1844 net.cpp:913] Cannot copy param 0 weights from layer 'layer81-conv'; shape mismatch.  Source param shape is 18 1024 1 1 (18432); target param shape is 255 1024 1 1 (261120). To learn this layer's parameters from scratch rather than copying from a saved net, rename the layer.
*** Check failure stack trace: ***
2_quantize.sh: line 8:  1844 Aborted                 (core dumped) decent quantize -model 2_model_for_quantize/v3.prototxt -weights 2_model_for_quantize/v3.caffemodel -gpu 0 -sigmoided_layers layer81-conv,layer93-conv,layer105-conv -output_dir 3_model_after_quantize -method 1
# step 3: compile ELF file
cp 3_model_after_quantize/ref_deploy.prototxt 3_model_after_quantize/deploy.prototxt
bash -v 3_compile.sh
#!/bin/bash
#Assume the dnnc-dpu1.3.0 is installed in /usr/local/bin
dnnc-dpu1.3.0 --prototxt=3_model_after_quantize/deploy.prototxt \
             --caffemodel=3_model_after_quantize/deploy.caffemodel \
             --dpu=4096FA \
             --cpu_arch=arm64 --output_dir=4_model_elf \
             --net_name=yolo --mode=normal --save_kernel
DNNC Kernel Information
Is there any way to solve this problem?
Re: Darknet 2 Caffe Quantize problem incorrect shape
"F0604 11:20:22.105778 1844 net.cpp:913] Cannot copy param 0 weights from layer 'layer81-conv'; shape mismatch. Source param shape is 18 1024 1 1 (18432); target param shape is 255 1024 1 1 (261120)."
It seems that the parameters for layer81-conv may not have been properly modified.
Perhaps do a search for "filters=255" in the original cfg file and check if an edit was missed?
Observer zorz123
I verify my yolov3.cfg everything is correct .
Any suggestion for me ?
Observer zorz123
Hi All
More details:
1. I train datknet on VOC base . (it is difference Xilinx use COCO)
2. When i change file yolov3.cfg (name [convolutional] -> [convolutional_my] : lines : 599, 685, 772 )
The problem not exist during quantize steps.
3. Now i hold no error:
#!/bin/bash
--dpu=4096FA \
dnnc-dpu1.3.0: /tmp/DNNC_V010_Package/dnnc/submodules/asicv2com/src/SlNode/SlNodeConv.cpp:81: void SlNodeConv::generate_convinit_op(const Arch&, const LCONV&, const YAggregationType&, const YAggregationType&, const BlockSmf&, const BlockSmf&, uint32_t, uint32_t): Assertion `conv_param.get_shift_cut() >= 0' failed.
3_compile.sh: line 9: 424 Aborted (core dumped) dnnc-dpu1.3.0 --prototxt=3_model_after_quantize/deploy.prototxt --caffemodel=3_model_after_quantize/deploy.caffemodel --dpu=4096FA --cpu_arch=arm64 --output_dir=4_model_elf --net_name=yolo --mode=normal --save_kernel
# step 4: prepare the package for the ZCU102 board
Observer zorz123
Hi ALL
Suspect problemi is in caffe weights file.
1. I compare network configuration file for caffe as below:
root@gd16:/mnt/data/test_darknet/Edge-AI-Platform-Tutorials/docs/Darknet-Caffe-Conversion/example_yolov3/1_model_caffe# diff v3_class80.prototxt v3_calss1.prototxt
diff v3_class80.prototxt v3_class1.prototxt
2564c2564
< num_output: 255
> num_output: 18
2874c2874
< num_output: 255
> num_output: 18
3184c3184
< num_output: 255
> num_output: 18
Conclusion :
All changes was convert corret.
for classe = 1 , num_output: 18
for classe = 80, num_output: 255
The problem exist in weights file .
Any suggestion how edit weights file ? (too big 250 Mb)
Observer zorz123
Update
1. I've check on coco base the same problem as voc base.
2. Training on one classe and coco base + Xilinx weights for 80 classes as initial. Incorrect results past 20000 iterations, error during conversion darknet2caffe
3. Training one classe and coco base + "0" weights as initial. Correct results past 2000 iterations, error during conversion darknet2caffe
Observer zorz123
Update.
1. Traing assume classes=2 filters=21 , base : coco  modify base to 1 classe the second class without images .
1.1 Verify past 3000 iteration , object detected 76 %
1.2 Convert darknet2caffe , I've get error as below:
1. F0612 06:22:16.884925 653 net.cpp:913] Cannot copy param 0 weights from layer 'layer81-conv'; shape mismatch. Source param shape is 21 1024 1 1 (21504); target param shape is 255 1024 1 1 (261120). To learn this layer's parameters from scratch rather than copying from a saved net, rename the layer.
2_quantize.sh: line 8: 653 Aborted (core dumped) decent quantize -model 2_model_for_quantize/v3.prototxt -weights 2_model_for_quantize/v3.caffemodel -gpu 0 -sigmoided_layers layer81-conv,layer93-conv,layer105-conv -output_dir 3_model_after_quantize -method 1
2. Traing assume classes=80 filters=255 , base : coco  modify base to 1 class the rest classes without images .
Under test
Observer zorz123
2.1 Test  on darknet result correct (person detected, label size ok , label name ok )
2.2 Test  on xilinx caffe + DPU  result correct (person detected, label size ok , label name not exist).
Next step is to check create new base , user defined objects
