jan.h
128b AXI device
I created a peripheral with 128b registers with 'Create and Package new IP...' and then manually changing C_S_AXI_DATA_WIDTH to 128. When I do that I see that the ADDR_LSB variable is not computed correctly. Here is a snippet of generated code:
    //local parameter for addressing 32 bit / 64 bit C_S_AXI_DATA_WIDTH
    //ADDR_LSB is used for addressing 32/64 bit registers/memories
    //ADDR_LSB = 2 for 32 bits (n downto 2)
    //ADDR_LSB = 3 for 42 bits (n downto 3)
    localparam integer ADDR_LSB = (C_S_AXI_DATA_WIDTH/32)+ 1;
For C_S_AXI_DATA_WIDTH == 128 it should compute ADDR_LSB = 4 instead of 5 which is computed with the expression above. Instead of computing the value as shown above it should be:
   localparam integer ADDR_LSB = log2(C_S_AXI_DATA_WIDTH / 8);
Right?
Jan
florentw
Hi @jan.h,
I think you are right. It seems that it has been written only for 32/64 bits not others register width.
If you check the VHDL code, there is this comment:
-- Example-specific design signals
It seems to say that it has been written on for this example, thus you should modify it.
However it would be better with a more adaptive way so I will report it to development.
Florent
