grx@
Abnormal program termination Vivado 2020.2
Getting following error on Vivado 2020.2
Abnormal program termination (EXCEPTION_ACCESS_VIOLATION)
Please check hs_err_pid186304.log
I have already gone through the below link but not helpful.
https://forums.xilinx.com/t5/Implementation/Vivado-2018-3-Abnormal-program-termination-EXCEPTION-ACCESS/td-p/996210
https://www.xilinx.com/support/answers/63279.html
Some observation :
  1. Tried the same RTL on Vivado 2017.4 then synthesis, P&R Implementation went through.
  2. Crash on Vivado2020.2 happens in the RTL elaboration phase.
florentw
Hi grx@
You are using windows 8.
This OS is not supported by 2020.2:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2020_2/ug973-vivado-release-notes-install-license.pdf#page=9
It was also not supported by 2017.4 BTW (but as windows 7 was supported, there was maybe more chances that the dependencies for windows 8 were similar):
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_4/ug973-vivado-release-notes-install-license.pdf#page=9
Florent
