Accessing RTL registers on PL from PS
I have a RTL design in PL in which I want to read/change the content of a certain register using onboard ARM processsor, ie from PS. Is it possible? Is there any documentation regarding this?
Thank you,
Tanmoy
Re: Accessing RTL registers on PL from PS
I think the best strategy would be to package the RTL up as an IP and connect to it over AXI.
I have moved this from 7-series to design entry. The folks here can talk you through what you need to do.
Thanks a lot klumsde, I'll try it.
My startpoint would be here: http://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug1119-vivado-creating-packaging-ip-tutorial.pdf
There is a more in depth User Guide here.
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug1118-vivado-creating-packaging-custom-ip.pdf
Keith
