moon5756
AppData/Roaming/Xilinx/Vivado/2017.4/XilinxTclStore/tclapp/xilinx/modelsim/common/utils.tcl": no such file or directory
I just downloaded Vivado 2017.4 and created a new project. I've got a error message in the tcl console saying
start_gui
create_project 180816_ofdm_siso C:/Users/myName_0/VivadoPrj/newProject -part xc7z020clg484-1
INFO: [IP_Flow 19-234] Refreshing IP repositories
INFO: [IP_Flow 19-1704] No user IP repositories specified
INFO: [IP_Flow 19-2313] Loaded Vivado IP repository 'C:/Xilinx/Vivado/2017.4/data/ip'.
couldn't read file "C:/Users/myName_1/AppData/Roaming/Xilinx/Vivado/2017.4/XilinxTclStore/tclapp/xilinx/modelsim/common/utils.tcl": no such file or directory
ERROR: [Common 17-69] Command failed: couldn't read file "C:/Users/myName_1/AppData/Roaming/Xilinx/Vivado/2017.4/XilinxTclStore/tclapp/xilinx/modelsim/common/utils.tcl": no such file or directory
I found that C:/Users/myName_1/AppData/Roaming/Xilinx/Vivado/2017.4/XilinxTclStore/tclapp/xilinx/
has projutils/common instead of modelsim. How do I fix this error? Or can I just ignore this error?
moon5756
@prathikm I manually changed some file names to get 2017.4 working but I finally went back to 2016.4 because I felt user interface is lighter and faster.
prathikm
Hi @moon5756,
What is the flow and files you used to get the error? Not sure why error is directly pointing to XilinxTclStore upon creating a new project. Can you still see this in 2018.2?
Prathik
Don't forget to reply, kudo, and mark the appropriate post as 'accept as solution'.
moon5756
