thomg
Artix 7 Vivado 2017.1 Commonn 17-39
I'm working on a test system that is controlled via a Digilent C7 Artix7 FPGA.
When until today all went well and I could program the FPGA with Vivado.
But this morning something happened, when I try to program the FPGA there now is a message saying: "ERROR: [Common 17-39]'program_hw_devices' failed due to earlier errors."
I don't know what to do with this message and I can't program the FPGA anymore.
Can someone help me with this problem?
Kind Regards,
Thom
bandi
HI @thomg,
Can you please share the earlier error message or share the vivado.log file here.
Sravanthi B
Thanks & Regards,
Sravanthi B
thomg
I see I have the wrong Bitfile settings.
This is the log from the Tcl Console:
ERROR: [Labtools 27-3303] Incorrect bitstream assigned to device. Bitfile is incompatible for this device.
INFO: [Labtools 27-3164] End of startup status: HIGH
ERROR: [Common 17-39] 'program_hw_devices' failed due to earlier errors.
nupurs
@thomg,
Can you verify that the bitfile that you are generating is for the same device that you are downloading the bitstream on?
Nupur
thomg
I have the Cmod A7 with the xc7a15tcg236-1 chip. I've selected this device from the Vivado list and still the error. I've also tried to uninstall and install Vivado again, also didn't work. I'm kind of desperate right now!
