[BD 41-951] Parameter LAYERED_METADATA not found on /clk_wiz_1/clk_out1 ERROR
I having a trouble,when i connected 1 clk_ to another clk(below)
I using 2 clk: clk_out1 and clk_out 2 with 166,667 and 200,000:
Messing: [BD 41-951] Parameter LAYERED_METADATA not found on /clk_wiz_1/clk_out1
I had readed some page https://japan.xilinx.com/support/answers/70087.html.
                                       https://www.xilinx.com/support/answers/70087.html
But i don't understand clearly
So Anybody help me fix this?
Thank you very much
tuan,
Scholar xilinxacct
Re: [BD 41-951] Parameter LAYERED_METADATA not found on /clk_wiz_1/clk_out1 ERROR
tuan94@
Does this solution give you any insight?
https://forums.xilinx.com/t5/Design-Entry/Receiving-this-error-when-Validating-Block-Design-BD-41-951/m-p/932298#M19273
Hope that helps
If so, please mark as solution accepted. Kudos also welcomed. :-)
Thank you for your answer,
I have SOLVED the problem,
When I create a Block IP,I create more 2 input ( Input A and Input B),
In "Edit Packed Ip " ,at Parameter Part of Input A have   LAYERED_METADATA ( not connected),
My work is connect it,
Thank you very much,
tuan,
