Scholar vanmierlo
BUFR doesn't divide properly
I'm not sure if this is the right subforum, but here goes.
I'm using a BUFR to divide an incoming clock by 7, but when I route the input and output clocks out to test pins I can see that sometimes the divided clock (clkdiv) is only 6 periods of the incoming clock (clock_i). But I do not see a glitch on the incoming clock_i to explain this. No need to say that the bits of my ISERDESE2 are slipping.
Here's my topology:
clk_in_p ---|=====\    |========|                 |====|
            |ibufds>---|idelaye2|---clock_i---+---|bufr|---------+-----clkdiv------------>
clk_in_n ---|=====/    |========|             |   |====|         |
| +---|=========| | |=====| |iserdese2| +---|bufio|---clkin----|=========| | |=====| | +------------------------clock_i----------->
Does anyone have an idea how to get to the bottom of this?
Btw. I'm using a Zynq 7010.
Maarten
Scholar vanmierlo
Re: BUFR doesn't divide properly
We enabled the terminating resister in the sending ADC and now the clock looks ok.
Scholar vanmierlo
Hmm, using a better oscilloscope I see I do have glitches.
Scholar vanmierlo
