Board interfaces no longer appear
After the last update of Vivado I no longer see the board interfaces for my AC701.
How do I correct this?
Why did this happen?
Re: Board interfaces no longer appear
After doing a reset on the PC I'm now getting the board tab.
In fact, the tab for the part interface does not appear when creating a new block design!
Hi @simchask,
What is returned at console when you type : get_board_parts -latest_file_version *ac701*
Ashish
xilinx.com:ac701:part0:1.4
But there is no board interfaces tab.
Hi @simchask,
May I know steps/flow you followed before coming across this issue (I am assuming that you are using Vivado 2018.1)?
Ashish
