Bug report: v2018.2 (64-bit) SW Build: 2258646
I received this error when working in the IP Packager.  Full information (company / project details masked) is contained within the .zip file.
# Xilinx Vivado v2018.2 (64-bit)
# SW Build: 2258646 on Thu Jun 14 20:02:38 MDT 2018
# IP Build: 2256618 on Thu Jun 14 22:10:49 MDT 2018
# Current time: Thu Jul 19 15:07:24 EDT 2018
# Process ID: 12168
# User: jstonge
# OS: Gentoo Base System release 2.1
# This file is an indication that an internal application error occurred.
# This information is useful for debugging. Please open a case with Xilinx.
# Technical Support with this file and a testcase attached.
java.lang.ArrayIndexOutOfBoundsException: Array index out of range: 0
at java.util.Vector.remove(Vector.java:831)
at com.jidesoft.grid.RootExpandableRow.a(Unknown Source)
at com.jidesoft.grid.RootExpandableRow.notifyChildDeleted(Unknown Source)
at com.jidesoft.grid.AbstractExpandable.removeChild(Unknown Source)
at com.jidesoft.grid.TreeTableModel.removeRow(Unknown Source)
at ui.utils.i.j.av.b(SourceFile:74)
at ui.utils.i.j.av.e(SourceFile:79)
at ui.utils.i.j.av.cleanup(SourceFile:69)
at ui.utils.i.j.av.clear(SourceFile:40)
at ui.views.B.b.K.Xp(SourceFile:327)
at ui.views.B.b.K.fGS(SourceFile:317)
at ui.views.B.b.aQ.refresh(SourceFile:103)
at ui.views.B.b.aQ.a(SourceFile:294)
at ui.frmwork.b.k.d(SourceFile:41)
at ui.frmwork.HTclEventBroker.i(SourceFile:266)
at ui.frmwork.HTclEventBroker.fireTclEvent(SourceFile:354)
at ui.data.coregen.packagerMisc.MiscCommands_addParameter(Native Method)
at ui.data.coregen.bN.c(SourceFile:291)
at ui.b.B.a.ak.a(SourceFile:248)
at ui.b.B.c.V.a(SourceFile:57)
at ui.b.B.c.V.a(SourceFile:46)
at ui.b.B.a.az.WS(SourceFile:107)
at ui.b.B.a.ai.WS(SourceFile:80)
at ui.b.c.g.actionPerformed(SourceFile:648)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022)
at ui.utils.o.b.a.fireActionPerformed(SourceFile:298)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252)
at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:289)
at java.awt.Component.processMouseEvent(Component.java:6533)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3324)
at java.awt.Component.processEvent(Component.java:6298)
at java.awt.Container.processEvent(Container.java:2236)
at java.awt.Component.dispatchEventImpl(Component.java:4889)
at java.awt.Container.dispatchEventImpl(Container.java:2294)
at java.awt.Component.dispatchEvent(Component.java:4711)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4888)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4525)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4466)
at java.awt.Container.dispatchEventImpl(Container.java:2280)
at java.awt.Window.dispatchEventImpl(Window.java:2746)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:80)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:90)
at java.awt.EventQueue$4.run(EventQueue.java:731)
at java.awt.EventQueue$4.run(EventQueue.java:729)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
at ui.frmwork.b.d.dispatchEvent(SourceFile:76)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:109)
at java.awt.WaitDispatchSupport$2.run(WaitDispatchSupport.java:184)
at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:229)
at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:227)
at java.awt.WaitDispatchSupport.enter(WaitDispatchSupport.java:227)
at java.awt.Dialog.show(Dialog.java:1084)
at java.awt.Component.show(Component.java:1671)
at java.awt.Component.setVisible(Component.java:1623)
at java.awt.Window.setVisible(Window.java:1014)
at java.awt.Dialog.setVisible(Dialog.java:1005)
at ui.b.c.g.setVisible(SourceFile:917)
at ui.b.c.g.a(SourceFile:330)
at ui.b.c.g.a(SourceFile:205)
at ui.b.c.g.bD(SourceFile:348)
at ui.b.c.g.showDialog(SourceFile:344)
at ui.b.B.a.az.showDialog(SourceFile:99)
at ui.views.c.p.r.run(SourceFile:39)
at ui.frmwork.a.dMm(SourceFile:131)
at ui.d.aJ.actionPerformed(SourceFile:289)
at javax.swing.AbstractButton.doClick(AbstractButton.java:376)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:833)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:877)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Hi @rayhoare,
I do not think Vivado 2018.2 is tested and recommended in Gentoo Linux distribution. In crash issues like these, it is recommended to first run the tool in compatible OS and check (link page. no. 11). If you have the IP packager flow which is causing this crash, I can definitely run at my end and check with the same flow.
Prathik
Don't forget to reply, kudo, and mark the appropriate post as 'accept as solution'.
