yukinon
Can Axi4-lite and Axi4 connect with slave?
I have packaged my module to IP with 2 port AXI4-lite Master.
Both of them and another axi4-full port master (from MicroBlaze) are connected with MIG (I believe its an axi4-full slave).
I wonder, Is this possible? Because I didn't find the ID in the AXI4-lite Master interface. And when I do the automated connect the ID (ARID, RID,...)of all of 3 masters connected to ground.
Can you help me out of this.
Thanks so much.
dpaul24
Do you mean you have something like this?
               <-- axi4lite --> MIG
Custom IP
uBlaze     <-- axi4full --> MIG
The MIG core can have only 1 axi i/f. So what about the arbitration if everyone wants to tx/rx data?
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
Asking for solutions to problems via PM will be ignored.
yukinon
hi @dpaul24,
yeah, my block design looks like that.
I thought Axi interconnect will do the arbitration but I do not understand how it works. Can you show me how to set it?
My expect is 2 masters of my custom IP will have the same priority and it's higher than uBlaze.
so if everyone wants to tx/rx data it will be myIP_M00 -> myIP_01 -> uBlaze.
dpaul24
You can use the Xilinx AXI interconnect IP in "N-to-1 AXI Interconnect" mode. The MIG side will be slave side. There is an in-built arbiter.
Read this doc: https://www.xilinx.com/support/documentation/ip_documentation/axi_interconnect/v2_1/pg059-axi-interconnect.pdf
See page 12 of the above document.
Excerpt- When multiple master devices arbitrate for access to a single slave device, such as a memory controller, use the AXI Interconnect core in a N-to-1 configuration.
yukinon
Hi @dpaul24,
Thanks for your help,
I wonder the axi4-lite haven't ID then how can AXI Interconnect determine the transaction belong to whom.
dpaul24
Is there any good reason why you are so much focused on ID signals?
See page7, "Fixed priority and round-robin arbitration". Choose the one that best fits your design.
