Can I get the example firmware source code for reading/writing eMMC storage in bare-metal firmware?
Dear Xilinx support and experts.
Thank you very much for your best supports.
I am using AVNET PICOZED 7Z030 board including 8GB eMMC(Multi-Media Card) storage.
I would like to read/write this eMMC storage in bare-metal firmware.
Can I get the example source code for this?
Thank you very much.
Re: Can I get the example firmware source code for reading/writing eMMC storage in bare-metal firmware?
There is a xilffs library that you can use:
https://github.com/Xilinx/embeddedsw/tree/master/lib/sw_services/xilffs
The wiki here has all the details on how to use this library in the SDK
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841771/xilffs
Dear stephenm
Thank you very much for your answer.
