Can't simulate Clocking Wizard in ISE 14.7
Hi!
I have developed a simple design for a VGA module where I need to produce a 40Mhz clock out of 100Mhz input for an Artix-7 (XC7A100T-CSG324) on an Digilent Nexys4 evaluation board. In order to aquire this clock I have used a Clock Wizard for a DCM. I have synthesise the desing, upload the bit file and everything works fine, as expected on the board.
I would like to extend the design and add more functionality. I order to achieve this, I need a test bench in parallel that will help me to continue the work. I have started by implementing the simplest test bech just to make sure it works. iSim doesn't want to start and the errors suggests that it doesn't see all the ports of the DCM:
ERROR:HDLCompiler:25 - "C:/Users/Popa/Desktop/FPGA/NEXYS4/DESIGNS/VGA/VGA_top.v" Line 131: Module <DCM_default> does not have a port named <CLK_IN1>.
ERROR:HDLCompiler:25 - "C:/Users/Popa/Desktop/FPGA/NEXYS4/DESIGNS/VGA/VGA_top.v" Line 133: Module <DCM_default> does not have a port named <CLK_OUT1>.
ERROR:HDLCompiler:25 - "C:/Users/Popa/Desktop/FPGA/NEXYS4/DESIGNS/VGA/VGA_top.v" Line 134: Module <DCM_default> does not have a port named <CLK_OUT2>.
ERROR:HDLCompiler:25 - "C:/Users/Popa/Desktop/FPGA/NEXYS4/DESIGNS/VGA/VGA_top.v" Line 136: Module <DCM_default> does not have a port named <RESET>.
ERROR:Simulator:778 - Static elaboration of top level Verilog design unit(s) in library work failed
 I don't understand what I'm doing wrong...the same code synthesize and produce succesfully the bit file and everything works fine but I can't simulate it. I'm using ISE WebPACK Design 14.7 (P.20131013).
My test bench:
module VGA_top_tb(
reg clk	  = 1'b0;
reg reset = 1'b0;
initial begin
	#5 reset  = 1;
	#30 reset = 0;
end
always begin
	#5 clk = !clk;
end
VGA_top VGA_DUT(
//inputs
.clk			(clk),
.reset_h		(reset),
.up_btn			(1'b0),
.down_btn		(1'b0),
.left_btn		(1'b0),
.right_btn		(1'b0),
//outputs
.red			(),
.blue			(),
.green			(),
.hs			(),
.vs			()
endmodule
DCM code:
`timescale 1ps/1ps
(* CORE_GENERATION_INFO = "DCM,clk_wiz_v3_6,{component_name=DCM,use_phase_alignment=true,use_min_o_jitter=true,use_max_i_jitter=false,use_dyn_phase_shift=false,use_inclk_switchover=false,use_dyn_reconfig=false,feedback_source=FDBK_AUTO,primtype_sel=MMCM_ADV,num_out_clk=2,clkin1_period=10.000,clkin2_period=25.0,use_power_down=false,use_reset=true,use_locked=true,use_inclk_stopped=false,use_status=false,use_freeze=false,use_clk_valid=false,feedback_type=SINGLE,clock_mgr_type=MANUAL,manual_override=false}" *)
module DCM
 (// Clock in ports
  input         CLK_IN1,
  // Clock out ports
  output        CLK_OUT1,
  output        CLK_OUT2,
  // Status and control signals
  input         RESET,
  output        LOCKED
  // Input buffering
  IBUFG clkin1_buf
   (.O (clkin1),
    .I (CLK_IN1));
  // Clocking primitive
  // Instantiation of the MMCM primitive
  //    * Unused inputs are tied off
  //    * Unused outputs are labeled unused
  wire [15:0] do_unused;
  wire        drdy_unused;
  wire        psdone_unused;
  wire        clkfbout;
  wire        clkfbout_buf;
  wire        clkfboutb_unused;
  wire        clkout0b_unused;
  wire        clkout1b_unused;
  wire        clkout2_unused;
  wire        clkout2b_unused;
  wire        clkout3_unused;
  wire        clkout3b_unused;
  wire        clkout4_unused;
  wire        clkout5_unused;
  wire        clkout6_unused;
  wire        clkfbstopped_unused;
  wire        clkinstopped_unused;
  PLLE2_ADV
  #(.BANDWIDTH            ("HIGH"),
    .COMPENSATION         ("ZHOLD"),
    .DIVCLK_DIVIDE        (1),
    .CLKFBOUT_MULT        (20),
    .CLKFBOUT_PHASE       (0.000),
    .CLKOUT0_DIVIDE       (20),
    .CLKOUT0_PHASE        (0.000),
    .CLKOUT0_DUTY_CYCLE   (0.500),
    .CLKOUT1_DIVIDE       (50),
    .CLKOUT1_PHASE        (0.000),
    .CLKOUT1_DUTY_CYCLE   (0.500),
    .CLKIN1_PERIOD        (10.000),
    .REF_JITTER1          (0.010))
  plle2_adv_inst
    // Output clocks
   (.CLKFBOUT            (clkfbout),
    .CLKOUT0             (clkout0),
    .CLKOUT1             (clkout1),
    .CLKOUT2             (clkout2_unused),
    .CLKOUT3             (clkout3_unused),
    .CLKOUT4             (clkout4_unused),
    .CLKOUT5             (clkout5_unused),
     // Input clock control
    .CLKFBIN             (clkfbout_buf),
    .CLKIN1              (clkin1),
    .CLKIN2              (1'b0),
     // Tied to always select the primary input clock
    .CLKINSEL            (1'b1),
    // Ports for dynamic reconfiguration
    .DADDR               (7'h0),
    .DCLK                (1'b0),
    .DEN                 (1'b0),
    .DI                  (16'h0),
    .DO                  (do_unused),
    .DRDY                (drdy_unused),
    .DWE                 (1'b0),
    // Other control and status signals
    .LOCKED              (LOCKED),
    .PWRDWN              (1'b0),
    .RST                 (RESET));
  // Output buffering
  BUFG clkf_buf
   (.O (clkfbout_buf),
    .I (clkfbout));
  BUFG clkout1_buf
   (.O   (CLK_OUT1),
    .I   (clkout0));
  BUFG clkout2_buf
   (.O   (CLK_OUT2),
    .I   (clkout1));
endmodule
Thanks!
Re: Can't simulate Clocking Wizard in ISE 14.7
Hi Gabor!
Thanks for your reply. I have noticed your observation that the naming of the DCM is different in the error message. I have re-name it before I post it in here but nothing changed. I have also tried "re-run all" to start the simulation but with no success.
In the end, I have manually removed the DCM instance and created a new one with the same parameters. This seems to solve the issue. Now works both on the board and in simulations. I'm not entirely sure what was the problem in order to avoid it next time.
Thanks for your help!
Professor
Professor
In your clock wizard code, the module name shows up as "DCM" but the error message is complaining about something called "DCM_default."  I wonder if the name "DCM" is reserved since it exists in library models for earlier devices.  You may just want to try renaming the module.
The only other thing I can think of is that sometimes when you enable incremental compiling in ISIM, it doesn't always re-compile everything that has changed.  I generally turn this option off.  Then try "re-run all" to start the simulation.
-- Gabor
Hi Gabor!
