Cannot remove ports in Package IP ports and interfaces vivado!!!
Hi, Dear All,
So i uses Vivado_hls to generate an interface including an ap_fifo newTask interfaces.
For example
newTask_full_n :  in std_logic;
newTask_write: out std_logic;
newTask_write_data : out std_logic_vector(31 downto 0);
and this interface appears in the GUI of the IP.
And i added some custom codes to connect these logic inside, so anyway i need to remove this interface from the GUI and only from the GUI.
I commented these ports in the top vhdl file, and i delete related lines in component.xml, auxiliary.xml and run_ippack.tcl inside the vivado_hls_project/.../impl/ip/ folder.
But i couldn't delete these ports, the remove ports just grayed.
Anyone have the some problem?
Thank you very much!
I resolved the problem by re-import these ports to the TOP vhdl file, these ports are previously associated to another sub-vhdl file.
And since the TOP vhdl file i already commented the ports, these ports just disappeared from the GUI.
How did you "re-import". I have a top level vhdl that I made changes to, removing some pins, and want to remove them from the symbol.
Hey, paul.gigliotti@coachcomm.com
What i did is just in the Package IP/Ports and Interfaces/,  right click on the interface you want to change and there is a import port option, which requires you to indicate the vhdl file which includes ports you want.
Hope this help you
Thanks, unfortunately these signals were not part of an interface, so I manually modified the component.xml file....
