tonyle
Cannot start or uninstall DocNav
Hello!
I'm unable to either start or uninstall DocNav on Windows 10 64-bit. When I start DocNav, I get the following error:
The application was unable to start correctly (0xc000007b). Click OK to close the application.
I cannot uninstall DocNav. The installation log file reads:
2019-11-11 11:52:11,392 INFO : com.xilinx.installer.api.e:? - Log file location - C:\Users\TLe\.Xilinx\xinstall\xinstall_1573501837413.log
2019-11-11 11:52:11,663 DEBUG: com.xilinx.installer.api.e:? - Memory usage -- Used memory: 4991 MB. Total memory: 8110 MB
Recent cpu usage for system: 0%
2019-11-11 11:52:11,921 DEBUG: com.xilinx.installer.data.postInst.InstallationRecord:? - Module already installed name:DocNav key:DocNav_MODULE
2019-11-11 11:52:11,922 DEBUG: com.xilinx.installer.data.postInst.InstallationRecord:? - Module already installed name:DocNav key:DocNav_MODULE
2019-11-11 11:52:11,924 ERROR: com.xilinx.installer.gui.InstallerGUI:? - There was an unexpected error:
java.lang.NullPointerException
	at com.xilinx.installer.data.postInst.InstallationRecord.updateIData(Unknown Source)
	at com.xilinx.installer.api.k.b(Unknown Source)
	at com.xilinx.installer.api.a.a(Unknown Source)
	at com.xilinx.installer.gui.InstallerGUI.<init>(Unknown Source)
	at com.xilinx.installer.gui.InstallerGUI.<clinit>(Unknown Source)
	at com.xilinx.installer.api.InstallerLauncher.main(Unknown Source)
I've also tried to uninstall and reinstall Java to no avail. Please help!
tonyle
I removed my entire C:\Xilinx directory (I only have DocNav installed on this PC) and Xilinx Design Tools from my Start Menu folder. Then I reinstalled DocNav 2019.2 from scratch. The same error appeared when I ran DocNav. When I tried to run the uninstaller, it stated that MSVCP140.dll was missing. A quick Google search indicated that I was missing or had a corrupted Microsoft Visual C++ 2015 Redistributable package. Once I installed this, DocNav launched just fine.
gabed
Hi @tonyle
This looks like a compatibility issue. I would suggest a google search with the error message.
Which version did you download? How are you attempting to uninstall DocNav?
Cheers
tonyle
I believe I'm trying to uninstall 2019.2 though I'm not certain since it won't run. I'm using the Uninstall DocNav link in the Windows start menu. The uninstall log reports the following:
2019-12-03 11:32:23,070 INFO : com.xilinx.installer.api.e:? - Log file location - C:\Users\TLe\.Xilinx\xinstall\xinstall_1575401456687.log
2019-12-03 11:32:23,578 DEBUG: com.xilinx.installer.api.e:? - Memory usage -- Used memory: 6030 MB. Total memory: 8110 MB
2019-12-03 11:32:24,284 DEBUG: com.xilinx.installer.data.postInst.InstallationRecord:? - Module already installed name:DocNav key:DocNav_MODULE
2019-12-03 11:32:24,285 DEBUG: com.xilinx.installer.data.postInst.InstallationRecord:? - Module already installed name:DocNav key:DocNav_MODULE
2019-12-03 11:32:24,288 ERROR: com.xilinx.installer.gui.InstallerGUI:? - There was an unexpected error:
2019-12-03 11:32:35,097 DEBUG: h.b:? - Read: HELLO
Unfortunately the only relevant search result from Google is this forum thread. :-|
tonyle
