a_chami
Change colors on Vivado
Since we use Vivado for many hours each day, using a low impact background color is very important for some of us.
However, while the background color is easily changed on the text editor, it is not available for changing (or I didn't find how to) for many of the main windows, most notably:
The IP integrator block diagram
Flow Navigator
The Hierarchy window
Source File properties
It would be very useful (and healthy) to be able to change the background of those windows.
BTW I am currently using Vivado 2017.1
Thanks!
Avi Chami MSc
FPGA Site
prathikm
Hi @a_chami,
Thanks for the screenshot. I have sent this enhancement request to the factory through CR-982658 - 'Color Changing Parameter Option for GUI in Vivado' specifically for the mentioned areas: Flow Navigator, Sources, Source File Properties and Block Design Backgrounds.
This will be discussed by the factory for future release.
Thanks & Regards,
Prathik
Please mark the post as an answer "Accept as solution" in case it helps to resolve your query.
Helpful answer -> Give Kudos
prathikm
Hi @a_chami,
There are few options to change colors of console, log, hierarchy view, schematic etc. in settings for 2017.1.
To give a fair opinion on this, I believe the default color scheme in Vivado 2017.1 has some kind of a low background color to it, right? :)
Thanks & Regards,
Prathik
a_chami
@prahitkm,
Thanks for your response.
None of the background options in all the fields I tested affects the windows I mentioned, namely, the IP integrator block design, the Flow Navigator, etc.
The gray background of some of those windows is better than the pure white used by many other applications. But for the ip integrator block design, IMHO, is still too bright. And I usually spend a lot of time looking at the block design.
For Vivado text editor (and also for Chrome, and other applications), I use a soft green color. At the end of the day the difference when using this soft green, compared to white or light gray, is huge. This is obviouly a subjective opinion, and that is the reason the colors should be available as a parameter for each one to be able to customize for its own taste and reduced strain on the eyes.
Avi Chami MSc
FPGA Site
prathikm
Hi @a_chami,
Can you please attach some screen shots of the GUI which you think requires a color variable parameter and which can help users based on their need? This will help us understand better as to exactly which GUI areas you are mentioning.
Sorry for the delayed response.
Thanks & Regards,
Prathik
a_chami
Hi @prathikm,
I have attached a screenshot. Some of the color options should control them... but I didn't see them having any effect.
Avi Chami MSc
FPGA Site
prathikm
Hi @a_chami,
Thanks & Regards,
Prathik
ronnywebers
Advisor
Advisor
@prathikm, some factory preset 'dark theme' would be great to have indeed, with many tools it's the first thing I do, change the default (white) theme to 'dark'
tom21091
I second the Dark theme preset.
rselma
Ditto. After whole day of programming with both Vivado and Vivado HLS I want to claw my eyes out.
Eclipse got the dark theme right:
nwc
And while you're at it; the zillions of different items to select colour for, is a way to time consuming and difficult way to do it.
Instead let me have the option to right-click any item/backgound on the screen, and then select what colour it should be in the future.
Also an export/inport function that work between versions of Vivado would be great... I tried to move my colour settings from Vivado 2015.2 to 2017.3.1 -> didn't work....
nwc
Me too... even your https://www.xilinx.com/myprofile.html got that right :-D
mk.anton
Hello. I was wondering, are there any updates on the Vivado background themes? Right now in 2017.4 all the problems discussed in this topic are still there. Any news on the "request to the factory through CR-982658 - 'Color Changing Parameter Option for GUI in Vivado' specifically for the mentioned areas: Flow Navigator, Sources, Source File Properties and Block Design Backgrounds" ? (the JIRA link doesn't seem to work).
Also I'd like to point out a few detected bugs, discovered while trying to change colors for a Dark Theme.
1. Just to give you an idea, I'm trying to make the text editor colors something like that:
However, whenever I restart the PC and re-launch Vivado, I get this:
As you can see, the color of 'Current Line Background' is displayed in default yellowish [255,255,215] color, even though the actual value in the Options is [64,64,64]. Need to manually change it to something like [64,64,65] for it to update and display the actual gray color again.
2. Also the black keyboard cursor is pretty much invisible on the dark background (hard to see even with highlight here):
3. Background for error (and sometimes warning) messages in Tcl console is wrong:
Somehow, the first character of the string is displayed correct, but the rest of the string has a default white background.
4. No color controls for "Simulation/Debug" session:
Can't see text on line 66  due to default yellow background.
P.S.: Vivado v2017.4 (64-bit), OS Win7 64-bit
denis77
Yes, dark background is pretty much unusable because cursor is not visible.
I found it's best to use a light theme and invert colors.
joshkleiner
How do you invert the colors?
Do you somehow apply this to the entire application?
I agree how there are a ton of "knobs" but it is hard to make it look good and many things are left out - all we really need is an additional theme or two that actually changes everything and people can also customize using the existing settings if they want to.
Thanks!
nhindle
philip.neighbour@welkinsciences.com, Could you post your themes *.xmltheme file or contents?  It is located %APPDATA%\Roaming\Xilinx\Vivado\2018.2\themes
Thanks in advance.
lyaa
To invert the colors, you can change the settings of your system's compositor.
On linux, it's easy to choose some shortcut for inverting the active window. For example, check the "Desktop Effects" window for KWin if you are using KDE Plasma or the negative plugin for Compiz if you're using Gnome.
nruggier
While not the most elegant answer, its relatively simple to invert colors with the magnifying tool in Windows.
https://www.youtube.com/watch?v=PbFCv_5QiCg
cmd + '+' opens the magnifier
ctrl + alt + 'i' inverts colors
Within the magnifier GUI, select Views >> Fullscreen
Set the zoom to 100%
Minimize the GUI
You're screen is now inverted and not destroying your eyes.
Every wanted to quickly invert the colours in Windows 10 so you can read the screen in a dark room without getting eye strain? Well watch this video or do th...
bklopp
The problem with using the magnififer in full screen to invert the colors is that all my other dark themes are now blindingly bright. Hopefully a dark theme will be added to a future version of vivado.
For thos who have asked, i invert colors useing this extesion (for Ubuntu):
https://extensions.gnome.org/extension/1041/invert-window-color/
Also attached is a picture I use for the waveform colors.
_risc_
Just checking, is this feature still not available? Would be awesome to add a "dark theme" for the entire application
Thanks!
jk_holz
Hey,
it has been four years since.
Have there been any new features since then?
