mountain902
Changing project from windows to linux
Hi, I'm new for vivado,
and I'm currently trying to do some tasks with ZCU_102_based_TRD with vivado on windows
I didn't do any changes on the original project and it ran synthesis without errors.
But when I copied the project to linux it showed some error message when running synthesis.
see the following:
ERROR: [Common 17-70] Application Exception: Unable to parse '/d500/455594/TRD/.Xil/Vivado-24278-XeonTitan2x00/dcp4/dcp.xml'. This can indicate that the checkpoint file is corrupt, or that there is insufficient free disk space to expand it.
I saw that one solution is run the tcl commands again on linux.
But as I mentioned, I downloaded the file online, which I can not find the tcl file.
Please let me know if there are any solutions.
Thanks in advanced
nupurs
@mountain902
Did you archive the project and take it to linux?
Or did you do "Save Project As" and take it?
Direct copying causes issues with the project file locations.
Nupur
mountain902
Hi, sorry for the late reply
I did "save project as..."  and moved to linux
but it doesn't fix the problem,
Are there any other possible solutions?
hemangd
Hi @mountain902,
Archive your project in windows and then unzip it in linux and open it there.  (To archive in Vivado GUI - go to file - archive project).
(Before archiving make sure your project is upto date) .
hemangd
hemangd
mountain902
I "Archived Project" and unzipped it on linux,
but it doesn't work,
I'll post my steps,
please check if I have made any mistakes,
hemangd
Hi @mountain902,
Does /d500/455594/.Xil/Vivado-31649-XeonTitan2x00/dcp4/dcp.xml exist?
If not, do you have write permission to that directory?
Make sure in linux that this project and directories have write permissions.
hemangd
hemangd
jxhekang
Reset all your ip core, and re'generate them. you will fix it.
