Connect_bd_net errors in IP Catalog flow
The project I am working, I tried to generate bitstream using Vivado in TCL mode. After the generation of IP I got the following messages including the error message,
# create_bd_cell -type ip -vlnv xilinx.com:hls:cnn:1.0 cnn_0
WARNING: [BD 41-1282] Ignoring parameter SIGNAL_SET
WARNING: [BD 41-1281] Parameter SIGNAL_SET is not defined on /cnn_0/streamOut. Setting parameter on /cnn_0/streamOut failed
# endgroup
# connect_bd_intf_net [get_bd_intf_pins cnn_0/streamIn] [get_bd_intf_pins axi_dma_0/M_AXIS_MM2S]
# connect_bd_intf_net [get_bd_intf_pins cnn_0/streamOut] [get_bd_intf_pins axi_dma_0/S_AXIS_S2MM]
# connect_bd_net [get_bd_pins cnn_0/ap_clk] [get_bd_pins processing_system7_0/FCLK_CLK0]
WARNING: [BD 5-235] No pins matched 'get_bd_pins rst_processing_system7_0_100M/peripheral_aresetn' # connect_bd_net [get_bd_pins cnn_0/ap_rst_n] [get_bd_pins rst_processing_system7_0_100M/peripheral_aresetn] ERROR: [BD 41-701] connect_bd_net requires at least two pins/ports, or one pin/port and a net ERROR: [BD 5-4] Error: running connect_bd_net. ERROR: [Common 17-39] 'connect_bd_net' failed due to earlier errors. while executing "connect_bd_net [get_bd_pins cnn_0/ap_rst_n] [get_bd_pins rst_processing_system7_0_100M/peripheral_aresetn]" (file "cnn_vivado.tcl" line 40)
I have no idea about this problem. I found in the forum that similar error occurred in Vivado 2014.1 version but recommended solution was to use 2013.4 version. But I am using 2016.4. Also, the IP I used was generated by 2014.2 version.
Re: Connect_bd_net errors in IP Catalog flow
Hi @rifat_buet,
-> This is the issue. Each tcl script is for a specific vivado version. So if the script has been generated for 2013.4, then you have to use this version to recreate the project. You can then move the full project from one vivado version to another.
The reason for that is because each vivado version has specific versions of IP. So you script is calling IP versions which do not exist in the newer versions.
Florent
Florent
@rifat_buet  It is saying that at that point in the script there is no component called rst_processing_system7_0_100M so get_bd_pins fails.
Hi @rifat_buet,
Florent
Florent
The best way to generate a script for a block design from vivado is without version information. I use this all the time without having any issues such as yours.
write_bd_tcl -no_ip_version.
-Pratham
Thanks , using the similar xilinx version solved the problem
