dreadedhill
Corrected installLibs.sh script for Vitis
After using the GUI installer, was instructed to run scripts/installLibs.sh. The script failed, so wrote a better replacement. Count this more as an answer than a question.
#!/bin/bash
echo "
==== Check that we can sudo."
sudo echo "We can." || {
    echo "ERROR cannot sudo!"
    exit 1
STAMP=$(date '+%Y-%m-%d_%H-%M-%S')
LOGFILE=$HOME/.Xilinx/xinstall/install_$STAMP.log
TESTFILE=/tmp/what-os.txt
    cat /etc/os-release
    lsb_release -a
} > $TESTFILE 2>&1
echo "
==== Logging into: $LOGFILE"
    < $TESTFILE grep -qi 'UBUNTU' && {
        sudo apt-get install -y libc6-dev-i386 net-tools graphviz unzip g++ libtinfo5
        ### gmake require for v++ flow (CIPS IP generation)
        sudo ln -s /usr/bin/make /usr/bin/gmake
    < $TESTFILE grep -qi 'REDHAT\|CENTOS' && {
        sudo yum install -y graphviz redhat-lsb openssl libXScrnSaver gcc gcc-c++ kernel-headers-`uname -r` kernel-devel-`uname -r`
    < $TESTFILE grep -qi 'CENTOS' && {
        sudo yum install -y epel-release
} 2>&1 | tee $LOGFILE
Tags (2)
