Custom AXI-Lite IP for float64
I want to design a custom axi-lite IP where data width is 64 bits to send from PS to PL doubles (float64). So, I created a new custom IP following vivado's wizzard that only gives a 32 bit option but I can change that later in the VHDL files.
As I want 64 bits, I changed C_S00_AXI_DATA_WIDTH and C_S_AXI_DATA_WIDTH from 32 to 64. Lastly, before packaging the IP, I changed in Customization Parameters C S00 AXI DATA WIDTH also from 32 to 64.
Then, I added the IP to the block design and I get the following error:
[Synth 8-97] array index 4 out of range ["/opt/vivado_prjts/AXI_Lite_float64/AXI_Lite_float64.srcs/sources_1/bd/design_1/ipshared/aada/hdl/Float64_v1_0_S00_AXI.vhd":221]
Which is:
	      loc_addr := axi_awaddr(ADDR_LSB + OPT_MEM_ADDR_BITS downto ADDR_LSB);
Then there is a case statement using loc_addr but as it is 2 bits (because ADDR_LSB=3 and OPT_MEM_ADDR_BITS=1) I don't see why I get an array index out of range error.
I found this thread dealing with it which could help but still, changing ADDR_LSB still does not resolve the issue. Is there something else to modify?
Thanks for the help.
File Float64_v1_0.vhd
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity Float64_v1_0 is
	generic (
		-- Users to add parameters here
		-- User parameters ends
		-- Do not modify the parameters beyond this line
		-- Parameters of Axi Slave Bus Interface S00_AXI
		C_S00_AXI_DATA_WIDTH	: integer	:= 64;
		C_S00_AXI_ADDR_WIDTH	: integer	:= 4
	port (
		-- Users to add ports here
        out_float64 : out std_logic_vector(C_S00_AXI_DATA_WIDTH-1 downto 0);
		-- User ports ends
		-- Do not modify the ports beyond this line
		-- Ports of Axi Slave Bus Interface S00_AXI
		s00_axi_aclk	: in std_logic;
		s00_axi_aresetn	: in std_logic;
		s00_axi_awaddr	: in std_logic_vector(C_S00_AXI_ADDR_WIDTH-1 downto 0);
		s00_axi_awprot	: in std_logic_vector(2 downto 0);
		s00_axi_awvalid	: in std_logic;
		s00_axi_awready	: out std_logic;
		s00_axi_wdata	: in std_logic_vector(C_S00_AXI_DATA_WIDTH-1 downto 0);
		s00_axi_wstrb	: in std_logic_vector((C_S00_AXI_DATA_WIDTH/8)-1 downto 0);
		s00_axi_wvalid	: in std_logic;
		s00_axi_wready	: out std_logic;
		s00_axi_bresp	: out std_logic_vector(1 downto 0);
		s00_axi_bvalid	: out std_logic;
		s00_axi_bready	: in std_logic;
		s00_axi_araddr	: in std_logic_vector(C_S00_AXI_ADDR_WIDTH-1 downto 0);
		s00_axi_arprot	: in std_logic_vector(2 downto 0);
		s00_axi_arvalid	: in std_logic;
		s00_axi_arready	: out std_logic;
		s00_axi_rdata	: out std_logic_vector(C_S00_AXI_DATA_WIDTH-1 downto 0);
		s00_axi_rresp	: out std_logic_vector(1 downto 0);
		s00_axi_rvalid	: out std_logic;
		s00_axi_rready	: in std_logic
end Float64_v1_0;
architecture arch_imp of Float64_v1_0 is
	-- component declaration
	component Float64_v1_0_S00_AXI is
		generic (
		C_S_AXI_DATA_WIDTH	: integer	:= 64;
		C_S_AXI_ADDR_WIDTH	: integer	:= 4
		port (
		out_float64 : out std_logic_vector(C_S_AXI_DATA_WIDTH-1 downto 0);
		S_AXI_ACLK	: in std_logic;
		S_AXI_ARESETN	: in std_logic;
		S_AXI_AWADDR	: in std_logic_vector(C_S_AXI_ADDR_WIDTH-1 downto 0);
		S_AXI_AWPROT	: in std_logic_vector(2 downto 0);
		S_AXI_AWVALID	: in std_logic;
		S_AXI_AWREADY	: out std_logic;
		S_AXI_WDATA	: in std_logic_vector(C_S_AXI_DATA_WIDTH-1 downto 0);
		S_AXI_WSTRB	: in std_logic_vector((C_S_AXI_DATA_WIDTH/8)-1 downto 0);
		S_AXI_WVALID	: in std_logic;
		S_AXI_WREADY	: out std_logic;
		S_AXI_BRESP	: out std_logic_vector(1 downto 0);
		S_AXI_BVALID	: out std_logic;
		S_AXI_BREADY	: in std_logic;
		S_AXI_ARADDR	: in std_logic_vector(C_S_AXI_ADDR_WIDTH-1 downto 0);
		S_AXI_ARPROT	: in std_logic_vector(2 downto 0);
		S_AXI_ARVALID	: in std_logic;
		S_AXI_ARREADY	: out std_logic;
		S_AXI_RDATA	: out std_logic_vector(C_S_AXI_DATA_WIDTH-1 downto 0);
		S_AXI_RRESP	: out std_logic_vector(1 downto 0);
		S_AXI_RVALID	: out std_logic;
		S_AXI_RREADY	: in std_logic
	end component Float64_v1_0_S00_AXI;
begin
-- Instantiation of Axi Bus Interface S00_AXI
Float64_v1_0_S00_AXI_inst : Float64_v1_0_S00_AXI
	generic map (
		C_S_AXI_DATA_WIDTH	=> C_S00_AXI_DATA_WIDTH,
		C_S_AXI_ADDR_WIDTH	=> C_S00_AXI_ADDR_WIDTH
	port map (
	    out_float64 => out_float64,
		S_AXI_ACLK	=> s00_axi_aclk,
		S_AXI_ARESETN	=> s00_axi_aresetn,
		S_AXI_AWADDR	=> s00_axi_awaddr,
		S_AXI_AWPROT	=> s00_axi_awprot,
		S_AXI_AWVALID	=> s00_axi_awvalid,
		S_AXI_AWREADY	=> s00_axi_awready,
		S_AXI_WDATA	=> s00_axi_wdata,
		S_AXI_WSTRB	=> s00_axi_wstrb,
		S_AXI_WVALID	=> s00_axi_wvalid,
		S_AXI_WREADY	=> s00_axi_wready,
		S_AXI_BRESP	=> s00_axi_bresp,
		S_AXI_BVALID	=> s00_axi_bvalid,
		S_AXI_BREADY	=> s00_axi_bready,
		S_AXI_ARADDR	=> s00_axi_araddr,
		S_AXI_ARPROT	=> s00_axi_arprot,
		S_AXI_ARVALID	=> s00_axi_arvalid,
		S_AXI_ARREADY	=> s00_axi_arready,
		S_AXI_RDATA	=> s00_axi_rdata,
		S_AXI_RRESP	=> s00_axi_rresp,
		S_AXI_RVALID	=> s00_axi_rvalid,
		S_AXI_RREADY	=> s00_axi_rready
	-- Add user logic here
	-- User logic ends
end arch_imp;
and Float64_v1_0_S00_AXI.vhd
library ieee;
entity Float64_v1_0_S00_AXI is
	generic (
		-- Width of S_AXI data bus
		-- Width of S_AXI address bus
	port (
		-- User ports ends
		-- Global Clock Signal
		-- Global Reset Signal. This Signal is Active LOW
		-- Write address (issued by master, acceped by Slave)
		-- Write channel Protection type. This signal indicates the
    		-- privilege and security level of the transaction, and whether
    		-- the transaction is a data access or an instruction access.
		-- Write address valid. This signal indicates that the master signaling
    		-- valid write address and control information.
		-- Write address ready. This signal indicates that the slave is ready
    		-- to accept an address and associated control signals.
		-- Write data (issued by master, acceped by Slave)
		-- Write strobes. This signal indicates which byte lanes hold
    		-- valid data. There is one write strobe bit for each eight
    		-- bits of the write data bus.
		-- Write valid. This signal indicates that valid write
    		-- data and strobes are available.
		-- Write ready. This signal indicates that the slave
    		-- can accept the write data.
		-- Write response. This signal indicates the status
    		-- of the write transaction.
		-- Write response valid. This signal indicates that the channel
    		-- is signaling a valid write response.
		-- Response ready. This signal indicates that the master
    		-- can accept a write response.
		-- Read address (issued by master, acceped by Slave)
		-- Protection type. This signal indicates the privilege
    		-- and security level of the transaction, and whether the
    		-- transaction is a data access or an instruction access.
		-- Read address valid. This signal indicates that the channel
    		-- is signaling valid read address and control information.
		-- Read address ready. This signal indicates that the slave is
    		-- ready to accept an address and associated control signals.
		-- Read data (issued by slave)
		-- Read response. This signal indicates the status of the
    		-- read transfer.
		-- Read valid. This signal indicates that the channel is
    		-- signaling the required read data.
		-- Read ready. This signal indicates that the master can
    		-- accept the read data and response information.
end Float64_v1_0_S00_AXI;
architecture arch_imp of Float64_v1_0_S00_AXI is
	-- AXI4LITE signals
	signal axi_awaddr	: std_logic_vector(C_S_AXI_ADDR_WIDTH-1 downto 0);
	signal axi_awready	: std_logic;
	signal axi_wready	: std_logic;
	signal axi_bresp	: std_logic_vector(1 downto 0);
	signal axi_bvalid	: std_logic;
	signal axi_araddr	: std_logic_vector(C_S_AXI_ADDR_WIDTH-1 downto 0);
	signal axi_arready	: std_logic;
	signal axi_rdata	: std_logic_vector(C_S_AXI_DATA_WIDTH-1 downto 0);
	signal axi_rresp	: std_logic_vector(1 downto 0);
	signal axi_rvalid	: std_logic;
	-- Example-specific design signals
	-- local parameter for addressing 32 bit / 64 bit C_S_AXI_DATA_WIDTH
	-- ADDR_LSB is used for addressing 32/64 bit registers/memories
	-- ADDR_LSB = 2 for 32 bits (n downto 2)
	-- ADDR_LSB = 3 for 64 bits (n downto 3)
	constant ADDR_LSB  : integer := (C_S_AXI_DATA_WIDTH/32)+ 1;
	constant OPT_MEM_ADDR_BITS : integer := 1;
	---- Signals for user logic register space example
	---- Number of Slave Registers 4
	signal slv_reg0	:std_logic_vector(C_S_AXI_DATA_WIDTH-1 downto 0);
	signal slv_reg1	:std_logic_vector(C_S_AXI_DATA_WIDTH-1 downto 0);
	signal slv_reg2	:std_logic_vector(C_S_AXI_DATA_WIDTH-1 downto 0);
	signal slv_reg3	:std_logic_vector(C_S_AXI_DATA_WIDTH-1 downto 0);
	signal slv_reg_rden	: std_logic;
	signal slv_reg_wren	: std_logic;
	signal reg_data_out	:std_logic_vector(C_S_AXI_DATA_WIDTH-1 downto 0);
	signal byte_index	: integer;
	signal aw_en	: std_logic;
begin
	-- I/O Connections assignments
	S_AXI_AWREADY	<= axi_awready;
	S_AXI_WREADY	<= axi_wready;
	S_AXI_BRESP	<= axi_bresp;
	S_AXI_BVALID	<= axi_bvalid;
	S_AXI_ARREADY	<= axi_arready;
	S_AXI_RDATA	<= axi_rdata;
	S_AXI_RRESP	<= axi_rresp;
	S_AXI_RVALID	<= axi_rvalid;
	-- Implement axi_awready generation
	-- axi_awready is asserted for one S_AXI_ACLK clock cycle when both
	-- S_AXI_AWVALID and S_AXI_WVALID are asserted. axi_awready is
	-- de-asserted when reset is low.
	process (S_AXI_ACLK)
	begin
	  if rising_edge(S_AXI_ACLK) then
	    if S_AXI_ARESETN = '0' then
	      axi_awready <= '0';
	      aw_en <= '1';
	    else
	      if (axi_awready = '0' and S_AXI_AWVALID = '1' and S_AXI_WVALID = '1' and aw_en = '1') then
	        -- slave is ready to accept write address when
	        -- there is a valid write address and write data
	        -- on the write address and data bus. This design
	        -- expects no outstanding transactions.
	        axi_awready <= '1';
	        elsif (S_AXI_BREADY = '1' and axi_bvalid = '1') then
	            aw_en <= '1';
	        	axi_awready <= '0';
	      else
	        axi_awready <= '0';
	      end if;
	    end if;
	  end if;
	end process;
	-- Implement axi_awaddr latching
	-- This process is used to latch the address when both
	-- S_AXI_AWVALID and S_AXI_WVALID are valid.
	begin
	      axi_awaddr <= (others => '0');
	    else
	        -- Write Address latching
	        axi_awaddr <= S_AXI_AWADDR;
	      end if;
	    end if;
	  end if;
	end process;
	-- Implement axi_wready generation
	-- axi_wready is asserted for one S_AXI_ACLK clock cycle when both
	-- S_AXI_AWVALID and S_AXI_WVALID are asserted. axi_wready is
	begin
	      axi_wready <= '0';
	    else
	      if (axi_wready = '0' and S_AXI_WVALID = '1' and S_AXI_AWVALID = '1' and aw_en = '1') then
	          -- slave is ready to accept write data when
	          axi_wready <= '1';
	      else
	        axi_wready <= '0';
	      end if;
	    end if;
	  end if;
	end process;
	-- Implement memory mapped register select and write logic generation
	-- The write data is accepted and written to memory mapped registers when
	-- axi_awready, S_AXI_WVALID, axi_wready and S_AXI_WVALID are asserted. Write strobes are used to
	-- select byte enables of slave registers while writing.
	-- These registers are cleared when reset (active low) is applied.
	-- Slave register write enable is asserted when valid address and data are available
	-- and the slave is ready to accept the write address and write data.
	slv_reg_wren <= axi_wready and S_AXI_WVALID and axi_awready and S_AXI_AWVALID ;
	variable loc_addr :std_logic_vector(OPT_MEM_ADDR_BITS downto 0);
	begin
	      slv_reg0 <= (others => '0');
	      slv_reg1 <= (others => '0');
	      slv_reg2 <= (others => '0');
	      slv_reg3 <= (others => '0');
	    else
	      if (slv_reg_wren = '1') then
	        case loc_addr is
	          when b"00" =>
	            for byte_index in 0 to (C_S_AXI_DATA_WIDTH/8-1) loop
	              if ( S_AXI_WSTRB(byte_index) = '1' ) then
	                -- Respective byte enables are asserted as per write strobes
	                -- slave registor 0
	                slv_reg0(byte_index*8+7 downto byte_index*8) <= S_AXI_WDATA(byte_index*8+7 downto byte_index*8);
	              end if;
	            end loop;
	          when b"01" =>
	                -- slave registor 1
	                slv_reg1(byte_index*8+7 downto byte_index*8) <= S_AXI_WDATA(byte_index*8+7 downto byte_index*8);
	              end if;
	            end loop;
	          when b"10" =>
	                -- slave registor 2
	                slv_reg2(byte_index*8+7 downto byte_index*8) <= S_AXI_WDATA(byte_index*8+7 downto byte_index*8);
	              end if;
	            end loop;
	          when b"11" =>
	                -- slave registor 3
	                slv_reg3(byte_index*8+7 downto byte_index*8) <= S_AXI_WDATA(byte_index*8+7 downto byte_index*8);
	              end if;
	            end loop;
	          when others =>
	            slv_reg0 <= slv_reg0;
	            slv_reg1 <= slv_reg1;
	            slv_reg2 <= slv_reg2;
	            slv_reg3 <= slv_reg3;
	        end case;
	      end if;
	    end if;
	  end if;
	end process;
	-- Implement write response logic generation
	-- The write response and response valid signals are asserted by the slave
	-- when axi_wready, S_AXI_WVALID, axi_wready and S_AXI_WVALID are asserted.
	-- This marks the acceptance of address and indicates the status of
	-- write transaction.
	begin
	      axi_bvalid  <= '0';
	      axi_bresp   <= "00"; --need to work more on the responses
	    else
	      if (axi_awready = '1' and S_AXI_AWVALID = '1' and axi_wready = '1' and S_AXI_WVALID = '1' and axi_bvalid = '0'  ) then
	        axi_bvalid <= '1';
	        axi_bresp  <= "00";
	      elsif (S_AXI_BREADY = '1' and axi_bvalid = '1') then   --check if bready is asserted while bvalid is high)
	        axi_bvalid <= '0';                                 -- (there is a possibility that bready is always asserted high)
	      end if;
	    end if;
	  end if;
	end process;
	-- Implement axi_arready generation
	-- axi_arready is asserted for one S_AXI_ACLK clock cycle when
	-- S_AXI_ARVALID is asserted. axi_awready is
	-- de-asserted when reset (active low) is asserted.
	-- The read address is also latched when S_AXI_ARVALID is
	-- asserted. axi_araddr is reset to zero on reset assertion.
	begin
	      axi_arready <= '0';
	      axi_araddr  <= (others => '1');
	    else
	      if (axi_arready = '0' and S_AXI_ARVALID = '1') then
	        -- indicates that the slave has acceped the valid read address
	        axi_arready <= '1';
	        -- Read Address latching
	        axi_araddr  <= S_AXI_ARADDR;
	      else
	        axi_arready <= '0';
	      end if;
	    end if;
	  end if;
	end process;
	-- Implement axi_arvalid generation
	-- axi_rvalid is asserted for one S_AXI_ACLK clock cycle when both
	-- S_AXI_ARVALID and axi_arready are asserted. The slave registers
	-- data are available on the axi_rdata bus at this instance. The
	-- assertion of axi_rvalid marks the validity of read data on the
	-- bus and axi_rresp indicates the status of read transaction.axi_rvalid
	-- is deasserted on reset (active low). axi_rresp and axi_rdata are
	-- cleared to zero on reset (active low).
	begin
	      axi_rvalid <= '0';
	      axi_rresp  <= "00";
	    else
	      if (axi_arready = '1' and S_AXI_ARVALID = '1' and axi_rvalid = '0') then
	        -- Valid read data is available at the read data bus
	        axi_rvalid <= '1';
	        axi_rresp  <= "00"; -- 'OKAY' response
	      elsif (axi_rvalid = '1' and S_AXI_RREADY = '1') then
	        -- Read data is accepted by the master
	        axi_rvalid <= '0';
	      end if;
	    end if;
	  end if;
	end process;
	-- Implement memory mapped register select and read logic generation
	-- Slave register read enable is asserted when valid address is available
	-- and the slave is ready to accept the read address.
	slv_reg_rden <= axi_arready and S_AXI_ARVALID and (not axi_rvalid) ;
	process (slv_reg0, slv_reg1, slv_reg2, slv_reg3, axi_araddr, S_AXI_ARESETN, slv_reg_rden)
	begin
	    -- Address decoding for reading registers
	    loc_addr := axi_araddr(ADDR_LSB + OPT_MEM_ADDR_BITS downto ADDR_LSB);
	    case loc_addr is
	      when b"00" =>
	        reg_data_out <= slv_reg0;
	      when b"01" =>
	        reg_data_out <= slv_reg1;
	      when b"10" =>
	        reg_data_out <= slv_reg2;
	      when b"11" =>
	        reg_data_out <= slv_reg3;
	      when others =>
	        reg_data_out  <= (others => '0');
	    end case;
	end process;
	-- Output register or memory read data
	process( S_AXI_ACLK ) is
	begin
	  if (rising_edge (S_AXI_ACLK)) then
	    if ( S_AXI_ARESETN = '0' ) then
	      axi_rdata  <= (others => '0');
	    else
	      if (slv_reg_rden = '1') then
	        -- When there is a valid read address (S_AXI_ARVALID) with
	        -- acceptance of read address by the slave (axi_arready),
	        -- output the read dada
	        -- Read address mux
	          axi_rdata <= reg_data_out;     -- register read data
	      end if;
	    end if;
	  end if;
	end process;
    out_float64 <= slv_reg0;
	-- User logic ends
end arch_imp;
Tags (3)
Re: Custom AXI-Lite IP for float64
@aripod,
My guess is that the problem you are having is that AXI-Lite is *ONLY* defined for a 32-bit bus width.  You can't use it with a 64-bit width, since that's no longer AXI-Lite.  If you need a 64-bit bus width, you will need to use the full AXI protocol.
One option going forward would be to use an AXI to AXI-Lite converter that isn't constrained by this requirement.
Dan
@aripod,
Dan
@dgisselq, that makes things clear. I used 2 32 bit registers and then on VHDL I concatenate them to get the 64 bits...I will keep in mind the axi full then.
