Deleting a part of block design wire
    I found something in vivado are very uncomfortable. eg. : I want to delete a part of the block design connecting wire, as shown in the following Figure,the yellow wire in the red wire frame. However, when I do this, it will delte all the yellow wire. O_O
    How can I just delet the yellow wire in the red wire frame while the other part remain?
    无标题.png .
Re: Deleting a part of block design wire
Hi @lucas_zyq,
Right-click and disconnect pin
Arpan
Hi @lucas_zyq,
Arpan
