Disable block in Vivado block diagram design
I have several blocks in my design which I would like to disable (not delete) from the design so that my build time is faster. Is there an easy way to do this from the GUI or by editing the hdl that doesn't break the block diagram view? Thanks
Scholar pratham
Re: Disable block in Vivado block diagram design
cepope@nc.rr.com No, There is no way to do this either
-Pratham
Scholar pratham
cepope@nc.rr.com Select the BD you wish to disable and right click disable.
shortcut is  ALT + MINUS
Through TCL
Example
set_property is_enabled false [get_files design_2.bd]
-Pratham
Hi cepope@nc.rr.com,
Use the following TCL command:
set_property is_enabled false [get_files  <project_path>/bd/design_2/design_2.bd]
In Vivado GUI. Select the block in File hierarchy and right click to Select Disable file as shown below:
--Syed
If you are asking for method to disable IP within block design then there is no such option provided.
Deepika.
Deepika.
Yeah, I see that an entire .bd file can be disabled but I am trying to disable a block within a .bd file leaving the other blocks alone. According to this last answer that isn't possible? Maybe there's a way to export the block(s) I want to disable as .bd files, while keeping the heirarchy, and then disable them? Thanks
Scholar pratham
-Pratham
