ERROR: [Common 17-356] Failed to install all user apps
hello, i have just install Vivado 2015.1 in windows. the  installation is done  and I have succesfully run settings but when I try to run vivado an error is displayed:
ERROR: [Common 17-356] Failed to install all user apps.
how can i solve this issue?thank you
Re: ERROR: [Common 17-356] Failed to install all user apps
Hello @aichamb,
Try setting the following environment variable as follows and then see the behaviour:
 XILINX_LOCAL_USER_DATA no
As we have seen other users setting that environment variable that avoided the issue for them.
Hope this helps
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Hi @aichamb,
Please check if the below Answer Record helps:
https://www.xilinx.com/support/answers/62908.html
Thanks & Regards,
Sravanthi B
Thanks & Regards,
Sravanthi B
hi @bandi, i saw a solution in "https://forums.xilinx.com/t5/Installation-and-Licensing/Vivado-failed-to-install-all-user-apps/m-p/558166#M9969" but i can't understand the meaning of "
This problem could occur when support and/or tclapp directories are missing in your $HOME/.Xilinx/Vivado/2014.4/XilinxTclStore.
To work around the issue, either copy the missing directories or do tclapp::reset_tclstore in tcl mode." can you explain to me more thank you
Hi @aichamb,
As mentioned in the above Answer Record, to work around the issue either copy the missing directories or run "tclapp::reset_tclstore" after opening Vivado in Tcl mode.
1. Open a command prompt,
2. migrate to C:\Xilinx\Vivado\2015.1
Ex: CD C:\Xilinx\Vivado\2015.1
3. Run settings64.bat.
4. Now run vivado -mode tcl once that is opened run command : "tclapp::reset_tclstore" and check if this helps.
Thanks & Regards,
Sravanthi B
Thanks & Regards,
Sravanthi B
i did but the error still .
Hello @aichamb,
Hope this helps
Kind Regards,
Anatoli Curran,
