philexqklip
ERROR: [Common 17-70]
When synth_1 and wait_on_run synth_1 was done, vivado reported an error and the implementation phase stopped:
ERROR: [Common 17-70] Application Exception: Failed to launch run 'impl_1' due to failures in the following run(s): synth_1.
But vivado didn't report specific error in synth_1 phase.
what's the real error?
Thanks!
hemangd
@philexqklip
Share vivado.log with us to evaluate.
Can you use edif (gate level netlist) or .v (netlist in verilog)  instead of .vm (structured netlist) and add it through add_files and then check you face the crash or not?
hemangd
hemangd
Hi @philexqklip ,
This is a crash of the tool.
Kindly share your testcase with tcl script to reproduce it.
Which Vivado version are you using?
Also try with GUI mode/project mode and see if you can able to pass synth and impl.
hemangd
philexqklip
the structure of tcl script is:
set  outputDir ****
file mkdir ***
create_project ***
add_files -norecurse ***.vm
add_files ***.v
add_files -fileset ***.xdc
set_property top *** [current_fileset]
launch_runs synth_1
wait_on_run synth_1
launch_runs impl_1 -to_step write_bitstream
wait_on_run impl_1
The vivado version is 2018.2
hemangd
@philexqklip
hemangd
philexqklip
Now using edif file can pass synthesis, but the edif file contains ram black box. How can I add the ram.xci into the edif netlist.
hemangd
Hi @philexqklip
Have a look into this thread for @siktap's comment. https://forums.xilinx.com/t5/Implementation/Blackbox-not-found-in-Vivado/td-p/425222
hemangd
